Last edit by: IB Advertising
Browse all: Steering and Suspension
- How to Install a Lowering Kit
Step by step instructions for do-it-yourself repairs
ISF front lowering kit
#76
Are these the same as for the GS/IS?
https://www.clublexus.com/forums/sus...p-install.html
#78
Super Now Front Lowering Kit has finally arrived 6 months later
. Want to thank Clark from VIP for not giving up. The problem was with manufacturer they have since fixed there manufacturing issues from what I've been told.
Will be install this kit on weekend will post up pick of ASAP. Question for lobuxracer and Figs once this kit has been installed is there anything in particular that I should be looking for to ensure there are no problems?
Some pic of kit
![ISF front lowering kit-2012-06-12-18.27.00.jpg](https://www.clublexus.com/forums/attachments/is-f-2008-2014/249664d1461119618t-isf-front-lowering-kit-2012-06-12-18.27.00.jpg)
![ISF front lowering kit-2012-06-12-17.42.41.jpg](https://www.clublexus.com/forums/attachments/is-f-2008-2014/249665d1461119618t-isf-front-lowering-kit-2012-06-12-17.42.41.jpg)
![ISF front lowering kit-2012-06-12-17.31.51.jpg](https://www.clublexus.com/forums/attachments/is-f-2008-2014/249666d1461119618t-isf-front-lowering-kit-2012-06-12-17.31.51.jpg)
![ISF front lowering kit-2012-06-12-18.42.12.jpg](https://www.clublexus.com/forums/attachments/is-f-2008-2014/249667d1461119618t-isf-front-lowering-kit-2012-06-12-18.42.12.jpg)
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Some pic of kit
![ISF front lowering kit-2012-06-12-18.30.40.jpg](https://www.clublexus.com/forums/attachments/is-f-2008-2014/249668d1461119618t-isf-front-lowering-kit-2012-06-12-18.30.40.jpg)
#79
This is interesting. I don't really want to wait another 6 months if I was to order this kit so I got to thinking....why not just go to Lowes and buy a few oversized nuts to slip over the bolts and use those as the spacers. It'd cost a few bucks. Also, are the stock bolts the same size as the VIP bolts?
#80
#85
Yes only 20mm in the front and stock in the back. I also added spacers and wider tires but in regards to height, only the 20mm kit. If you are going to order it, make sure is the one for the 3rd gen GS. Those are the ones that work for our ISF's.
