Old 12-12-14, 03:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
ISF front lowering kit
Old 07-02-12, 12:11 PM
  #121
DCoolBeans
DCoolBeans's Avatar
Nice find Figs. Thanks for taking your time to check this out for us
Old 07-02-12, 02:55 PM
  #122
VtotheJ
VtotheJ's Avatar
After seeing the findings from FIGS and reviews from Weapon F, it's probably better to just get Swift Springs. They drop the car 1" in front and 0.6" in back. Including installation and the springs it's $400, depending on the shop
Old 07-02-12, 09:07 PM
  #123
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,082 Likes on 2,474 Posts
Originally Posted by FIGS
I looked at this again this weekend Just be warned that due to the geometry of the knuckle and additional spacing will push the caster back and can have impacts on the steering response. It may also make more tire interference depending on how thick it is and what tireyou run.
RCA spacers were originally designed for flat knuckle vehicles, but the gen2 IS and Gen 3 GS have a slanted knuckle.
The clever student will also notice these spacers will definitely change bump steer too. The angle between the steering rack and the tie rod end is going to change significantly.
Yes, this is an easy way to drop the suspension. No, it is not without negative impact on the suspension's design. That's frustrating, but at least it's pretty clear this won't work well for track driven cars.
Old 07-02-12, 11:55 PM
  #124
t4orce
t4orce's Avatar
Totally agree with the comments above. When I run on track or autokhana, I'll be removing my spacers. I'll leave them on for the street for the aesthetics.
I'm one of the few strange people who is satisfied with the OEM suspension. I'll improve my driving style before making major changes to the car.
Old 07-03-12, 12:34 PM
  #125
Weapon F
Weapon F's Avatar
Just a quick update last week I put the car back to stock the handing characteristics return that's just the way I like it to me performance outweighs asthetics. I'm no expert but there may be some long term damage to suspension by keeping these spaces in for any length of time. Just like VJ stated anyone looking for small drop just go with swift spring and set of FIGS Mega Arms and call it day.
Old 07-06-12, 04:51 PM
  #126
SPoon22
SPoon22's Avatar
Just got rid of these for some coils. The front feels way too loose. PM me if interested in the 20MM kit.
Old 12-13-12, 10:58 PM
  #127
VegasISF
VegasISF's Avatar
Just bought this kit and was planning on installing but i'm not liking what you guys are saying about how it won't work well with a track driven car. I drive my car on the track often but also want to lower just the front. I had also purchased a set of swift springs. My main question is...is it safe to drive on track with installing only the front swift springs and continue to run the stock springs on the back?
Old 12-17-12, 11:12 PM
  #128
robertrios
robertrios's Avatar
I was also thinking about doing just spring in the front...but this is also an option since I do not track...Vegas lmk if you sell your kit.
Old 12-18-12, 11:25 AM
  #129
anxiouz
anxiouz's Avatar
Fantastic thread. Subscribing.
Old 12-30-12, 07:46 AM
  #130
tonnetje
tonnetje's Avatar
is this lowering kit working on a normal IS250/350 as well?
Old 12-30-12, 03:27 PM
  #131
Weapon F
Weapon F's Avatar
Tonnetje if you read thread you would see that this lowering kit will not work on second gen ISF, IS350/250 this kit changes the geometry of the suspension. Which in turn effects several ares of suspension most notably being caster.If you want to lower your IS get springs or coilovers.
Old 12-31-12, 05:01 AM
  #132
tonnetje
tonnetje's Avatar
lowerd it already on eibach prokit springs
but have a litlle gap over, i thought this is my solution
but it isnt
thanks for the reply
greetz tonnetje
Old 10-29-13, 10:31 PM
  #133
robertrios
robertrios's Avatar
anyone still running these for normal DDing without negative side effects?
Old 10-30-13, 01:32 AM
  #134
SPoon22
SPoon22's Avatar
Do not use RCA spacers for the IS F. It will mess with the caster as mentioned in this thread many times. I had them previously installed and you can tell the wheel is off-centered in the fender. Not to mention it throws the whole car out of sync while driving. Do yourself a favor and get coils. I regretted not doing so in the first place. I sold my set to a better suited application on a GS.
Old 10-30-13, 09:12 AM
  #135
Rossi
Rossi's Avatar
but it isnt
greetz tonnetje
Eibachs (front ONLY)
245/35/19 (F) 275/30/19 (R) Michelins PSS
15mm H&R spacers (all around)
Love my gaps
Quick Reply: ISF front lowering kit
