audible shift indicator volume
Old 01-26-12, 02:34 PM
lexuz125th
lexuz125th's Avatar
Default audible shift indicator volume
I was wondering if it is possible to increase the volume of the shift indicator sound?
Old 01-26-12, 02:53 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,988 Likes on 2,413 Posts
No, there's no adjustment to the shift warning sound.
We could really use the Corvette's HUD here and have a flashing screen for a shift indicator, but unfortunately, Lexus does not give us a HUD.
Are you hearing impaired? Just curious because I can hear it with the windows down at the track with a helmet on.
Old 01-26-12, 02:56 PM
caco666
caco666's Avatar
The new tach shows a three stage LED indicator, it seems like you can really make good use of the visual cues without the need for an audible one.
For current owners, is the shift indicator sound too annoying? Or do you get used to it? And can it be turned off?
Old 01-26-12, 03:00 PM
SeanGTS
SeanGTS's Avatar
I don't mind it, I definitely panic when I hear it as I forget about it. I think this means I need to drive it harder more often.
Old 01-26-12, 03:05 PM
Joe Z
Joe Z's Avatar
Received 1,063 Likes on 586 Posts
Exclamation
I love when the VSC audible warning goes off... !!!!
~ Joe Z
Old 01-26-12, 06:07 PM
zapa
zapa's Avatar
~ Joe Z
+1 it is such a great sound
Old 01-27-12, 12:32 AM
lexuz125th
lexuz125th's Avatar
the reason why i asked about increasing the volume, is because it sounds pretty low especially if you are on the track with the windows down. I took a ride in another F and it was much louder.
Old 01-27-12, 06:04 PM
StrykarISF
StrykarISF's Avatar
Not adjustable no, wish it was. Mod it to blast the horn instead! jk that would get old fast on the track haha
Old 01-28-12, 09:04 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
~ Joe Z
I've only heard it once when I found a large gravel patch in the middle of a turn. I know the car's limits and how not to push beyond them. That's why I drive at the track...
Old 01-28-12, 12:35 PM
DCoolBeans
DCoolBeans's Avatar
it'd be nice to be able to adjust the volume
Old 01-29-12, 08:28 AM
eviioiive
eviioiive's Avatar
Perhaps its in the secret menu...? There were many options in there that werent labeled well...
Old 01-29-12, 05:09 PM
kamileon88
kamileon88's Avatar
There's no adjustment. I checked personalized settings with tech stream
Old 01-30-12, 08:27 AM
JKweezy
JKweezy's Avatar
http://www.amazon.com/exec/obidos/AS...tokaikaratedo/
the sound amplifier "as seen on tv"... comes with two so you can use it in both ears to hear that beep clearly... can't vouch for how well it works...
Old 01-30-12, 05:56 PM
TripleBlkF
TripleBlkF's Avatar
i think its annoying, i know my car well enough to know the sound it makes at higher rpm. i like the idea of it but only if there was a on/off switch.
but having the beep and shift lights on the new one is just a bit excessive
sizquik
IS F (2008-2014)
06-28-21 05:03 AM
frotiss
IS F (2008-2014)
06-26-12 02:01 PM
bigblack06
Hybrid Technology
06-30-11 10:10 PM
bluwater
GX - 1st Gen (2003-2009)
09-09-10 03:18 PM
Quick Reply: audible shift indicator volume
