ARP wheel studs
Leander311 (10-01-18)
Tech Info Resource
OEM studs are 36mm from the back of the hub to the end of the threads. ARP says these are 2.600 inches, so 66mm. That's quite a bit more for closed lugs like ours. Hub face thickness appears to be 8mm.
The OEM lugs have 36mm of thread total with 12mm from the nose end to the washer. OEM rim face thickness is 15mm. So there is 28mm of OEM stud sticking out of the hub face. There is 9mm of room left in the OEM lug for additional stud length with OEM wheels and studs. You'd have 21mm of stud preventing you from using closed end lugs with the ARP studs installed.
The following 2 users liked this post by lobuxracer:
JohnMorgan (09-29-18),
3rdelement
02-25-06 10:18 AM
