Still drifting to the right
When I bought the car in October the car had the same drift to the right and I thought it was just an alignment issue. I just aligned the car a week ago and I still have the drift.
I've read people with these issues but I thought it was fixed for the 2010+. Is this a know issue for my year? If I take it to the dearer are they gonna give me beef for taking it to another shop for the alignment?
Also I have the 245/285 tire combo Continental's. I put those on a month ago
Here's the alignment sheet
Thx
Thx
I've read people with these issues but I thought it was fixed for the 2010+. Is this a know issue for my year? If I take it to the dearer are they gonna give me beef for taking it to another shop for the alignment? Also I have the 245/285 tire combo Continental's.
Thx
Thx
try finding a really flat surface to drive on and see if the car still pulls. if not, then its the road crown that is cause you to pull right. also, make sure your suspension components are in good shape and tires are evenly worn
Great timing! I was going to post a similar thread today. I bought my 2011 2 weeks ago and have 500 miles on it. I too notice it moves to the right when I take my hands off the steering wheel. I've tried it on many different road surfaces including left curves that bank slight to the left "/". On a left curve, it seems to want to move straight and when the bank goes back to straight, it fades off to the right again. I'm stumped considering I only have 500 miles on the car.
Tech Info Resource
Swap the fronts to rule out tire conicity - if it still pulls right with the fronts swapped, then the problem is somewhere else. Measure the rear tires to be sure they are the same diameter - if they're not, the car will want to turn toward the smaller diameter tire - we do this intentionally on circle track cars to help them turn left.
Thx
Thx
Yes. Did you want to see the before specs?
And to answer Denver, yes the car still pulls to the right at slow speeds in a parking lot. On the highway, the street, ect.
I don't think traditional alignment shops will adjust the subframe...most of them will strap your car to the alignment machine and align your wheels, not the subframe. You may have better luck at a frame shop. I got mine done at one of the best alignment shops in SoCal...West End Alignment...Darshana S...
I had this problem when I bought new Continental DWS's for the front (replaced OEM Bridgestones). The dealer double checked the alignment and switched the wheels around too. It still pulled to the right. I ended up replacing the DWS's with Michelin PS2's and the pulling went away. Tirerack just swapped out the tires no questions asked. So lesson learned was to not have different tires on the front than the back (all seasons up front/summer in the back). Are your Continentals all the same?
