How Long to WARMUP the car in the COLD
I sometimes pulloff after a minute then Im off, but slowly until the engine temp gets to the middle. I won't go caveman on it until the oil temp is almost in the middle too (never quite gets to the middle for the engine oil temp)
Is this logic right? Do u guys pamper her before she warms up or doesn't really matter. Lexus guy told me it'll warm up as you go. If it was like zero degrees out then yes Id let it idle for 10-15 minutes.
Talk to me people of this World.
Im in California, so not as nearly as cold as you guys but this is my routine regardless in the mornings.
A gentleman that I knew would beat the crap out of his LS1 Corvette (obviously not a lexus with Ti valvesprings) when cold and ended up cracking a spring and caused the valve to collapse and destroy his motor.
I try to not "beat" or go wide open throttle if I can help it until the car has 3 bars for the oil temp. You might also notice that the car's manual mode will not shift if the car's AT Fluid is not warmed up to temp as well.
When I leave in the morning and the car is cold, I just drive like a "normal" person and it warms up on its own without an issue.
I've always let all my cars idle for about a minute or two before I start driving. Even when I do start driving, I'm light on the throttle until it full warms up. Better safe than sorry... and then again, I'm also in CA where the coldest it gets all year is maybe 30 degrees hahaha
A cold engine is not well lubricated and idling definitely does not help. By idling a cold engine, you slow down the warm up process and allow metal to rub and pound without protection of engine oil. you should drive once the car is started, but be gentle until motor oil is hot, that's when it becomes less viscous and coats all vital parts well.
even a minute of idling is insane for modern engines.
Tech Info Resource
I let my car warm up for about 2 seconds before I put it in gear and drive off. My (lack of) wear is documented very well in the Blackstone thread and the valve lash adjustment thread. The engine warms up best under load, but not heavy load. You should never go WOT under two bars on the oil temp. The engine doesn't care about water temp from a wear perspective, only oil temp. Ideal is to see three bars on oil temp before asking for full performance, but when it is really cold, you might not see this for 30 minutes or more.
