Downshifting in M Mode with Sport Enabled
Old 02-17-12, 06:28 PM
ISF001
ISF001's Avatar
Default Downshifting in M Mode with Sport Enabled
Will the F always accept the downshift in the M mode with sport enabled?
I have noticed that in the Sport mode alone, it sometimes will refuse the downshift.
As someone new to the F, I would appreciate some guidance here.
Old 02-17-12, 06:34 PM
MisterSkiz
MisterSkiz's Avatar
It will only refuse to shift in Manual mode if you are requesting a gear too low for the current speed, or if the auto trans fluid is not up to a certain temperature (as far as I know).
Also, if you leave the car in manual mode, it will downshift for you as you slow down.
What exactly are you experiencing?
Old 02-17-12, 06:37 PM
LexusNN
LexusNN's Avatar
Im pretty sure. Like MisterSkiz said, it will only refuse it if its too low so that it doesnt blow your tranny and you dont get that major jolt.
Old 02-17-12, 06:52 PM
ISF001
ISF001's Avatar
I just found the ISF Shift Thread. It appears that I simply need to take my foot off the accelerator to get the rev matched downshift in the M mode with Sport enabled. Is there a difference in downshifting if the VDIM is disabled?
You can see that I clearly do not have much experience with the F's shifting capabilities and methods.
Old 02-17-12, 08:32 PM
James7
James7's Avatar
unless the '12's are that much better, the foot of the accelerator accompanied with a flick of the paddle will do a rev matched downshift... i think just letting off the accelerator causing a downshift would be bad in some cases...
Old 02-18-12, 10:28 AM
wsMB
wsMB's Avatar
can you put up the link to that thread? thanks in advance.
Old 02-18-12, 10:07 PM
avgj0F
avgj0F's Avatar
What were the speed and gear you want to down shift to?
Old 02-19-12, 06:06 AM
ISF001
ISF001's Avatar
I took the F out on an open stretch where I could hit 120 and test the rev-matched downshifts in the M mode with sport enabled. It worked beautifully--a very exhilarating experience--and addictive as well.
It was clearly my lack of knowledge. It blipped with every downshift and upshifted with lightning speed.
It's a ride.
Old 02-19-12, 06:13 AM
ISF001
ISF001's Avatar
The ISF Shift Speed link is:
http://www.clublexus.com/forums/is-f...t-speed-2.html
Old 02-19-12, 03:15 PM
LiLS
LiLS's Avatar
It's a ride.
so u did what u said in this thread earlier
Nimo
GS F (2016-present)
03-15-18 05:22 AM
BAlbright
RC F (2015-present)
08-31-15 05:17 PM
gdcheng
NX - 1st Gen (2015-2021)
05-13-15 07:13 PM
tx_is300
Performance
02-13-15 01:48 PM
spotxc
03-30-14 02:17 PM
Quick Reply: Downshifting in M Mode with Sport Enabled
