To be done
Guys my warranty expires this month I don't want to get an extented before it expires I want to take it in, is there anything I should have them look for thanks
Hey, Unfortunately, I don't think they can really, "Look" for anything unless you have an issue with the car, and if you did that issue is what you would tell them to fix.
I would just have them put it on the diagnostic, OBD2 and make sure all is well.
I would turn down radio and see if there any any rattles, or creaks, or strange engine noises, or look for any rubber bushings that could be starting to crack, as well as the rubber moulding around the doors, or trunk?
Good luck
Good luck
Tech Info Resource
Under warranty. No typical.
I was wondering the approximate mileage of water pump failure reported by CL members. Is this around 30,000 miles, 60,000 miles,etc. I am pretty new here on CL so I have not seen all the reported incidents.
Tech Info Resource
There's no consistent number. Some were early around 30,000, mine was a little over 62,000. The rest have been somewhere in between. So, just keep an eye on it, and when it goes, get it replaced before the engine runs dry or the warranty expires.
renman33
RX - 3rd Gen (2010-2015)
09-28-18 01:27 PM
lmschuur
01-16-13 10:58 PM
bagwell
04-07-10 04:44 PM
