AD2P in my IS-F
Zazzan - Much like you, I was looking for the same solution. The GROM unit seemed to be the best fit. Here is my review. Hope it helps:
https://www.clublexus.com/forums/is-...tegration.html
I'm thinking about getting one of these, but would prefer to keep calls through the factory nav.
hyb1212id,
Thanks for the review!! Sounds exactly like what I want, does anyone have any info on the dice electronic mediabridge?
http://diceelectronics.com/media-bridge-info
Trying to find a unit that suports BT 4.0 with aptX? supposed to make the BT streaming quality much better. See the below product that claims to have support for this.
http://theauris.com/products/arctic-white
Bought an I-wave adapter to use on my Vaistech in the time being but I want to swap it out for something that supports BT by default.
Hyb1212id, did you say that you can't change playlists though the screen when using BT? Even while stopped and the NAVI is unlocked?
So apparently, I found that this device is supposed to do BT and text to screen while in BT meaning the buttons on the wheel work and you'll see the track name.... I'm about to order it and let you guys know.
http://www.neocaraudio.com/cars/2008_LEXUS_ISF/BTY1UV6
This unit may work as well since it has AVRCP
http://usaspec.com/page.php?PageID=19
zazzn
IS F (2008-2014)
18
04-25-14 05:10 PM
