Check VSC problem
So after installing new bulbs and led bulbs in my headlights my cars dash is lit up!
check vsc, vsc, red triangle, the traction control light are all on...
The only thing i disconnected was the MAF sensor but I installed it back on...
any idea? car drives fine![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
I'd always get my codes read before resetting the ecu. It could be just a fuse that blew
When you removed the intake, did you also disconnect a hose? Look at your intake area and make sure everything is plugged in
hmm ill have to look into the fuse. I didnt disconnect any hoses jsut 2 10mm botls to moved the box around. I did take off the front scoop though. but i made sure it was secure when i put everything back together...only thing i disconnected was the maf sensor.
