wheel fitment question
03-08-12, 03:51 PM
i searched but couldnt find a good answer
so here my planned set up
Swift Springs
19x8.5 +35 245/35/19
19x9.5 +35 275/30/19
will i have to worry about rubbing if i roll my rears?
03-08-12, 04:19 PM
yes, with 375's you will
SHOULD be fine with that setup (275's) of course
03-08-12, 04:21 PM
03-08-12, 04:38 PM
Your gonna want a 245/30/19 in the front....
03-08-12, 07:02 PM
^^^^245/30/19 will be in inch too small in OD. 245/35/19 is the correct size for the fronts.
Lou
03-08-12, 07:20 PM
yep yep.... 30 is too thin.. if you want to match the height go 40 series
03-08-12, 09:12 PM
^^^^No! 245/40/19 is too tall
Lou
03-10-12, 05:43 AM
19x5 +35 in the rear with 275/30R19 will probably work with stock suspension height...it will be close though. If you drop it, my guess is you will rub a bit on big bumps. 19x8.5 +35 with 245/35R19s should work just fine in the front.
FPLinek
08-21-22 07:47 PM
eliteskill
SC- 1st Gen (1992-2000)
29
03-24-10 02:44 PM
sincityIS
08-24-07 09:06 AM
klthomas
Wheels, Tires & Brakes Forum
10-26-06 06:55 AM
Gs L-tune
14
09-06-05 02:26 AM
