Heavy rub and clunk when turning
Bought a 2008 lexus ISF just over 1 month ago. The car was a certified series used car which came with winter rims and tires installed in addition to the summer tires and rims. Just tonight I installed the OEM rims and tires, tires are brand new PS2's installed by the dealer on the OEM rims and when I make a hard turn to the left the car rubs and clunks, if i turn right it does the same but not as bad. Any ideas on what it could be?
I am having the exact same issue. When the steering is turned beyond a certain angle, like 1turn through full lock, (usually on u-turns) or turning out of a really tight parking space, the front wheels feel like they're scrubbing heavily.
Just wondering if anyone knows who the problem could be? Car is 100% stock.
Good memory, I search and found this post. Looks like it could be normal.
Exact same issue as described, sometimes when near or at full lock, it does feels like I ran over something. My fronts are nearing the end of treadwear, so will find out if new tires will help.
https://www.clublexus.com/forums/is-...n-reverse.html
https://www.clublexus.com/forums/is-...low-turns.html
Lou
Tech Info Resource
If it's really rubbing with OEM rims and tires, something is seriously wrong. Sure, the tread winds up and releases making a noise at parking lot speeds, but that's it. If anything rubs, you need to find out what, why, and correct it immediately.
what you said makes total sense now: "the tread winds up and releases making a noise at parking lot speeds" thats exactly what it feels like. thank you
MrG4Life
Wheels, Tires & Brakes Forum
08-19-06 02:50 PM
