FIGS Track Day at HPR
#31
Basicly the nannies will frequently apply the brakes and then they overheat in a track environment and then brake fade will be a factor...
Hopefully he'll correct me if i misspoke....
#32
Tech Info Resource
I turn off the stability controls. On a tight track like CMP they'll fade the front brakes before you know it.
#33
No traction control, with the right tires you will never need it. I accidentally left it on during one lap and it was brutal how much it takes you out of it.
4 more weeks till 2-peice rotors get here. We are also planning on an OSGiken LSD swap. Amsoil Dominator oil to see if it has any impact on oil temps.
We will start NASA HPDE (from the bottom) on the 15th.
More vids and pics to come.
Mike
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
#35
#36
Pricing will be around $1300 for the fronts which is still significantly less than anything else from Japan.
Still working on releasing the penske shocks but its been tough since all their tech guys are deployed supporting the F1 and Indy teams.
__________________
mikersoft
IS F (2008-2014)
13
05-15-17 09:47 AM
