Tire Question
hey sorry guys these are iPhone photos and i mean all of them are. You will get what you are talking about when you look at them all. the first two are of the tires are you guys asked then next one is a photo I took only a few minutes after the F18 crash in virginia beach. Enjoy guys
ya so i no longer have the right to complain about iPhone pictures from now on. But onto the tires they are sweet so much more grip everywhere for sure helps with the understeer i was having. When i go to launch i get a little wheel spin but thats probably cause the tires are still new but when i mean a little like hard to notice. I don't get crazy wheel hop like i used to have.
Ya there is some bulge, but it is not bad at all. The car looks a lot better with the upsized tires fills out some gaps for sure. So now that i have a few miles on these tires I would say they are a huge improvement over the stock potenzas. So much more dry grip. Around the bends the sidewalls seems to be harder and it does not understeer as much. The biggest improvement i have seen is in wet performance. The cars power seems so much more manageable and i was able to run my same 0-60 time in the soaking wet with these tires as I was able to run with the stock potenzas in dry conditions. These tires are very quiet also. If they wear well i will for sure get another set of them. I am running 37 PSI all the way around.
Genuine what are you running??
Do you all think 37 psi is too low?
