Tire Question
Old 04-03-12, 06:42 PM
zapa
zapa's Avatar
Default Tire Question
Will all 285/30/19s fit on the stock rims in the rear. I need a 100% answer before I order tires. I would have gone with the Conti dw in that size but they no longer make them.
Also if you have any suggestions it would really help.
Thanks guys
Old 04-03-12, 07:24 PM
ISFSteve
ISFSteve's Avatar
I had Conti DWS in that size on my stock rims with no issues at all. The DWS's are an excellent all season tire and I loved them. I have a set with less than 1000 miles on them if you are interested.
Thanks guys
Old 04-03-12, 07:28 PM
SeanGTS
SeanGTS's Avatar
Yep, they fit. I run the continental dw in that size.
Old 04-03-12, 07:33 PM
zapa
zapa's Avatar
Im in VA so we don't get much snow here so there is no need for a all season tire, but thanks for the offer. I think I might just go with the RE-11 in 275 30 19. Unless you all know of any negative things about these tires.
Old 04-03-12, 08:17 PM
DCoolBeans
DCoolBeans's Avatar
It's all about trying to match the OD of the OEM tire set up with the new tires your purchasing
Old 04-03-12, 08:27 PM
ISFSteve
ISFSteve's Avatar
275 would work as some run that size but they are not as close to original diameter as 285's but will work. Can't say for your tire selection as I do not have first hand experience with them. Some have said they liked them but I find helpful going on to Tire Rack or a similar site that lists owners reviews and see what they have to say. Noise and tire wear are some of the biggest complaints with some brands and/or certain models.
Old 04-03-12, 08:30 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
RE-11, pretty much as close to an R compound street tire as you are going to find... awesome performance...
they wear fast, but not terrible...
Old 04-03-12, 08:36 PM
zapa
zapa's Avatar
Thanks for the help guys but what OD should I try to shoot for and what will happen if I am alittle bit off of the OD. I want to got with 285s. But I do t have time to send the tires back because I am risking a blow out already. I have been looking all over the place but I have no idea what to order. Stock sizes are also too small for my driving style they spin way to much and in the rain I don't feel like the car is planted very well.
Thanks guys
Old 04-04-12, 07:31 AM
zapa
zapa's Avatar
285/30R19 Bridgestone Potenza S-04 Pole Position I ended up going with these lets hope they fit!!! They should be here tomorrow and i will get the put on and let you all know how everything works out.
Old 04-04-12, 07:50 AM
flowrider
flowrider's Avatar
Received 1,920 Likes on 1,355 Posts
Thanks guys
I just got off the phone with Continental, and they still make the 285/30/19 DW tire, but they are on and have been on national back order for some time. The Bridgestone S-04 should be fine. I'm assuming your changing the fronts also. In a HI-PO tire, matching front to rear is especially important due to the rubber compounds used in them and the fact that, even though it may be subtle, the handling does change over time due to wear.
As I indicated in my Continental DW thread, my set has developed a sing which I am unhappy with. I am working with Continental Tire now to resolve the issue. If I can't, my next set of tires could very well be the S-04s.
Lou
Old 04-04-12, 09:29 AM
Evil Teo
Evil Teo's Avatar
^^Lou why not try the Vredestian? i will run those after my conti dw are worn.
Old 04-07-12, 01:46 PM
zapa
zapa's Avatar
Hey i just wanted to thank you all for you help. so my set up is 245/35 and 285/30 SO-4 Pole Positions. The tires were mounted today and fit perfectly. There have been no rubbing issues so far. The cars seems to feel more stable and there is for sure better traction. The tires are not broken in yet so i will let you know on the performance once i have about 500-1000 miles again.
Old 04-07-12, 03:07 PM
tinbui
tinbui's Avatar
@ZAPA , post some pics plz . thanks for ur time
Old 04-07-12, 05:08 PM
GenuineKid
GenuineKid's Avatar
Glade to hear that! i just purchased mine and will be here on monday! btw, how you did you pay for everything. tires, shipping if applicable, tax, mounting and balance.
Old 04-07-12, 07:37 PM
zapa
zapa's Avatar
my grand total which included tires, shipping, mounting, balancing, and an alignment came out to be around 1400 maybe a little less
Quick Reply: Tire Question
