If u don't mind what is your nitrous setup? I really need a kit for my car and want to know the best one everyone is having the best times with. Thank u
Here was my install thread. It's a zed wet v8 efi kit with custom brackets and glove box set up. I can run between 75-100 shot on pump and 125-175 with different jets and ms109 from vp race fuels
17x10 Volk re30 with Mickey Thompson et street radial 275/40... They rub the little tiniest bit on the drive to the track.Running 12-13psi in the tires at the strip.
I have seen multiple people running 17" rear wheels with their drag setup. Does anybody know if Mkiv Supra TT front &/or rear wheels would clear ISF rear brakes? I believe the specs are 17x8 & 17x9.5 + 50mm, but I'm not entirely sure. the 17x8s would be good to run 245/45R17 drag radials and the 17x9.5s would be good for 275/40E17 drag radials...that is if they clear the rear brakes. I was curious because I think cheap Supra TT wheels would be fairly easy to find.
my volks posted above are 17x9.5 +40 and clear perfect
