sikky o2 simulator
Old 04-20-12, 06:12 PM
BryanLeISF
BryanLeISF's Avatar
Default sikky o2 simulator
Anybody have the wiring instructions for the microprocessor that comes with sikky headers? I bought the headers from Mitch and he didn't have the instructions. Getting them installed tomorrow and looking for some help. Thanks in advance!
Old 07-05-12, 04:26 PM
MRxSLAYx
MRxSLAYx's Avatar
Bump... Anyone have this info?
Old 07-05-12, 04:32 PM
ISF4life
ISF4life's Avatar
u can try dl and print at sikky.com ? just let you know, the instructor is right but the pic was wrong.
http://www.sikky.com/view_item.php?id=148&catid=15
Old 07-05-12, 05:55 PM
anxiouz
anxiouz's Avatar
Haven't read up much about this but most O2 simulators have a similar technique to what Evo guys (and myself) have done which is just a lug extender that moves the sensor out of the test-pipe or other non-cat exhaust path.
I actually didn't know there was a wired chip to deal with for any set of headers.
/subscribing so that I can learn more
Old 07-05-12, 07:03 PM
RX7 RAGE
RX7 RAGE's Avatar
Here it is boys. Y'all can thank me in the future with a beer or something.
File Type: pdf
Old 07-05-12, 07:05 PM
MRxSLAYx
MRxSLAYx's Avatar
When I come to Cali to start my movie career ill hook it up with a 12 pack. Thanks !!!!!
Old 07-05-12, 07:07 PM
RX7 RAGE
RX7 RAGE's Avatar
That sounds like a plan. I'll remember that you said this then.
Old 07-18-12, 09:05 AM
eoph
eoph's Avatar
Followed the instructions, but I'm getting CEL, VSC, traction control light. I double checked yesterday, then reset the ecu, and this morning driving to work CEL came on again. ODBC reader said it was both the downstream o2 sensors. I thought the simulator doesn't even use the signals from the o2 sensors unlike the PPE ones? Do i just have a bad simulator?
Thanks,
J
Old 07-18-12, 09:29 AM
ISF4life
ISF4life's Avatar
Check the splices wires make sure they are good, also double check it, wrong wires resulted in cel, vsc. Scanner would be very helpful , to see which code ?
here some of my connection , hope that help.
Old 07-18-12, 10:58 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,962 Likes on 2,400 Posts
Those vampire taps are notoriously unreliable. There are much better ways to tap wires that don't damage the loom and allow you to restore the wiring to its original OEM condition. They cost a little more, but the wire won't internally corrode over time and end up breaking under the insulation.
Old 07-18-12, 11:36 AM
ISF4life
ISF4life's Avatar
Thanks, that all we had at the shop.
Old 07-22-12, 12:14 AM
eoph
eoph's Avatar
So i tripled checked the o2 simulator was wired correctly, but i'm still getting CEL. I tried using a multimeter on the red and black wires on the simulator. 12v when ignition is on, and 13.3v when engine is gone.
Old 07-22-12, 02:37 PM
eoph
eoph's Avatar
Picture of the wiring attached.
Should check the voltage on the yellow wire?
Old 07-25-12, 08:56 AM
eoph
eoph's Avatar
I had to set the multi-meter to 200m to get a reading(Connected black wire on multi-meter to black wire on simulator, and the red wire on multi-meter to the yellow wire on multi-meter). With the car running, it gave a constant reading of "02.5". Not sure sure what's the conversion to volts, but maybe that's a bit low?
I'm sure some smart forum members can help . My battery voltage next to the temperature gauge on the cluster seems healthy, dead center.
Old 07-25-12, 09:24 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
That's about the ugliest wiring/soldering I've seen in a very long time. How sure are you the connections are good?
A good soldered wire looks like this:
I won't go into why soldering a wiring harness is a horribly bad idea because the horse is already out of the barn and long gone.
If I were you, I'd either fix the connections, or take it to someone who is a competent wiring tech and can solder it properly.
Quick Reply: sikky o2 simulator
