Wrong Tire Size? Need help please
I finally got my Enkei PF-01s, 18 x 9.5, +45 offset with Toyo 285/30/18s on all four corners.
I think the front ones are too wide for the car. There's only couple of millimeters space between the front tier and suspension.
I went with the above setup based on many recommendations on this forum. Where did I go wrong? What shall I do?
Please help.
Please help.
here is the PM's SCCA Forums and I exchanged regarding this topic.... those sizes seemed to have worked for him....![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
(its' in reverse order.... most recent on top and oldest on bottom...)
Re: What wheel tires are you using?
Kumho V710's
Anytime!
Quote:
Originally Posted by ERDoc74
Thank you SOOO Much!! which kumho's?
Quote:
Originally Posted by SCCAForums
Hi, Absolutely... 18 X 9.5 PF01 45mm Offset fit perfectly... square setup with 285/30/18 Kumho/Hoosier (your preference). Great clearance as well.
Carbotech Brake Pads (Phenomenal Stopping and easy to swap out at track, and not ruin your factory pads). (XP10 front XP8 Rear. I believe)
Borla True Dual Exhaust: Part# 12656
Drop in filter (the blue one? AFE maybe?) '
Hope that helps!
Thanks,
Dave
Hi Dave, I was thinking about getting something like the enkie PF01's like you have for the track and some semi slick track tires.... I've heard you are running a square setup with 285's all around... What size of wheel and offsets are u running and what tire and a sizes are you using? Do you have any issues with clearing stock brakes with your setup or fender clearance issues? Sorry for bugging you, I'm a newbie and don't want to buy something that's not going to work.
Also I've heard youve done really well in races with your setup... Would you reccomend your setup for me ( a HPDE newbie) who just plans on going to 5-7 HPDE's per year??
__________________
RaceCar: '89 Chevrolet Camaro 1LE CMC2/TTC No# 75
'09 CMC2 NASA National Champion
'08 PTB NASA National Champion
'05 T2 Runoffs Qualifying Track Record Holder
'05 F-Stock Pro Solo Nat'l Champion
'04 F-Stock Solo 2 Nat'l Champion & '04 F-Stock Pro Solo Nat'l Champion
'03 ESP Solo 2 Nat'l Champion & '03 ESP Pro Solo Nat'l Champion
'97 G-Stock Solo 2 Nat'l Champion & '97 G-Stock Pro Solo Nat'l Champion
Kumho V710's
Anytime!
Hope that helps!
Thanks,
Dave
__________________
There's barely any space between the tiers and front suspensions. I'm able to slide a piece of paper and move it freely though when the car is jacked (fourth picture).
I drove the car for a couple of KM's and there was a winding noise at speed.
I noticed some scratching marks on the suspensions arms when I removed the wheels.
Tech Info Resource
Sounds like the Toyos are little on the wide side of spec. Kumhos and Hoosiers are known to fit. There are variances between manufacturers.
Toyo was recommended to me by Vivid Racing! I assume they know what they are talking about.
I really don't know what to do now!
