Metallic click sound coming from left rear axle area
#76
How soon after pads and rotors did it begin?
I ask because I did front brakes on my wife’s car, and the next day it started to sound like a wheel bearing was going out and it had some wobble. I chased it down to the brand new autozone rotor not being true. It had some kind of warp. The pads and rotor also oddly glazed, even after bedding them in. I had the rotors milled and put oem pads on, and the issue is gone.
I started chasing the brakes because the sound happened not less than 24 hours after replacing them, so maybe you can start assessing those first by a visual inspection and varied braking. See if any specific action replicates the sound.
#77
My sound is not really a “click.” The best way I can describe it is it sounds like some string or wire is caught in the axle.
#80
If you don't have a good impact gun, you can use a narrow gouge to lift the mashed in part, or you can grind on the nut with a grinding tool (I once did this with my die grinder and a porting carbide tool I have) where it is staked and remove the stake that way. I found the impact gun to be the most expeditious method by far when I was doing clutch jobs on Scion tCs in 2006.
#81
Depends on what tools you have available. If you have a decent impact wrench, don't worry about it, just hit it with the gun and be happy. After installing the new nut, just take a smallish punch (1/8" or 3mm) and hammer the spot above where the groove is to mash the threads into the groove and you're done.
#83
#84
I can recreate the click if I place it in gear, hold the brake and lightly press accelerator. Once it loads up it will click..that is how I determined it was coming from the left axle. I replaced bolt and it did not fix the issue for me, the noise is still there occasionally but I do not notice it getting worse or causing and drivability issues. Not sure what the long term affects might be (mine has been noisy for years) - but I suspect none, it's just a little annoying to hear it click occasionally.
#85
Just got a “performance” alignment from a new shop and immediately noticed this clicking sound when I lifted off the throttle. I thought for sure they failed to properly torque the rear toe links or camber arms. I went back over everything with proper torque specs and the noise is still there. So glad I found this thread! Going to install new axle nuts ASAP. Thanks
#87
RudyRC51
06-24-10 01:42 AM
