Street 0-60 Times - Game ON!!
Old 05-10-12, 06:59 AM
FOVFR421
FOVFR421's Avatar
Default Street 0-60 Times - Game ON!!
My son and I have had some fun recently running some 0-60 runs from a light and timing them. The only problem is that I don't have anything to compare the numbers to. I only have the intake mods of a JoeZ pipe and Tom's filter along with the RMI Scoops. I have done 3 runs as my son has timed them and they are as follows:
5.4 - full auto, sport mode, traction control on, VSC on
5.3 - same
5.0 - full auto, sport mode, trac off, VSC off
I really want to run under 5, but the biggest thing that I notice is the fly by wire delay after I step on it.
Game on!!!! Please post all numbers good and bad so that we can all compare. Also, if anyone has some mad skills, please pass on some driving skills/tips to improve our times.
Thanks, be safe and have fun!
Old 05-10-12, 07:04 AM
IS350atWOT
IS350atWOT's Avatar
M mode with paddle shifters is faster than full auto.
Old 05-10-12, 07:40 AM
staman
staman's Avatar
Racing on the street with your son. Good job.
Old 05-10-12, 07:57 AM
CaptAwsm
CaptAwsm's Avatar
Its only 0-60! On most highways thats about the speed limit.
Old 05-10-12, 08:03 AM
4everkidd
4everkidd's Avatar
a race generally takes more than one person, and OP never mentioned it being down town, or at a busy intersection.
My old man used to punch it in his camaro when I was a kid, 500+ hp, I loved it and turned out alright.
I ran a 4.4 in Seattle, but have not been able to get it under 4.9 in Calgary. Elevation is definitely a factor, and I also found wider stickier rear tires helped significantly from stock.
Sport mode, manual both times.
Old 05-10-12, 08:13 AM
scrosby
scrosby's Avatar
Seriously? He's doing 0-60mph from a stop light, not racing another car. Probably less dangerous than merging onto a freeway..
Old 05-10-12, 08:32 AM
MisterSkiz
MisterSkiz's Avatar
What are you using to measure your times? Most magazines, etc use more than just stop watches.
Old 05-10-12, 08:37 AM
FOVFR421
FOVFR421's Avatar
It's a very technical solution.... when my son feels the car move or the light turn, he hits start on his ipod touch and when he sees 60 he stops. Can't get much more accurate than that !! I know there are some OBDII apps that will connect and time, but I don't have the dongle or a good app to use. Any suggestions would be appreciated.
Old 05-10-12, 08:45 AM
4everkidd
4everkidd's Avatar
Have your son download dynolicious onto his iPod touch. Enter your car weights, specs, drivetrain loss and it will measure your 0-60 using its gyroscopic motion sensors. It can actually give you a rough estimate of he and torque as well.
There have been some very close estimates as well
Old 05-10-12, 08:52 AM
Justin2JZ
Justin2JZ's Avatar
Sounds like fun OP. I really want to invest in a VBox but they're so damn expensive. And how high up are you in Virginia?
Old 05-10-12, 09:01 AM
staman
staman's Avatar
Seriously. If your on private property do what you want. When your in public i.e (an intersection with a light as the OP stated) its incredibly irresponsible.
Old 05-10-12, 09:02 AM
zapa
zapa's Avatar
I did a 4.4 a few weeks ago measuring the same way. I know I can do better now with my wider tires though
Old 05-10-12, 09:25 AM
boostftw
boostftw's Avatar
get a bluetooth obd2 doogle off eBay or amazon and then download TORQUE on andriod, then post back with results
Old 05-10-12, 09:27 AM
DCoolBeans
DCoolBeans's Avatar
You need one of these(GTech) or a VBox. I et you have fun with either
Old 05-10-12, 11:52 AM
LBmtb
LBmtb's Avatar
I have a Kiwi Wifi (OBDII sensor with wifi) and will be headed to the track this Saturday. I'll try and remember to try this out.
Quick Reply: Street 0-60 Times - Game ON!!
