Voseen CV3
Old 05-10-12, 08:10 PM
MjThind
MjThind's Avatar
Default Voseen CV3
What are your specs offset, width, lug pattern etc and what tire are you running...
Thanks in Advance
-Mjthind
***EDIT***-Just noticed I spelled Vossen wrong :0
Old 05-10-12, 10:37 PM
Evil Teo
Evil Teo's Avatar
im not sure what the offsets are but I am gettin 20x9 for the fronts and 20x10.5 for the rear. Getting Nitto Invos 245/30/20 and 285/25/20. I just rolled my rear fenders. Had a friend do it for me.
Old 05-11-12, 04:45 AM
ISFSteve
ISFSteve's Avatar
This is also my exact set up.
Old 05-11-12, 06:09 AM
obby
obby's Avatar
offset should be at 32 front and 45 rear if i remember corectly.
Old 05-11-12, 05:51 PM
CalitriSC
CalitriSC's Avatar
Yup 32 front and 45 rear. And rolling the rear fenders is a must.
Old 05-12-12, 06:33 AM
Juanca
Juanca's Avatar
Hey Evil, why did you roll the fenders? Is you ISF dropped? With 20x10.5 you shouldn't.
Does anyone know the weight of the CV3s on 20s? Given that they're cast I guess they're not light, but I'm curious.
Old 05-12-12, 06:40 AM
Evil Teo
Evil Teo's Avatar
i am dropped by a little bit. the weight is a little bit heavier than stock not by much though and you probably won't notice.
Old 05-12-12, 06:46 AM
ISFSteve
ISFSteve's Avatar
Two people in the back will cause some rubbing over dips without a drop.
Old 05-12-12, 07:08 AM
Nate008
Nate008's Avatar
I thought they were +38 fronts. I guess I am mistaken. Mine rub everyday driving carefully and with only me in the car and I'm on stock suspension. I need my fenders rolled.
Old 05-12-12, 07:45 AM
Evil Teo
Evil Teo's Avatar
did you guys installed tpms on your wheels? wanted to know if the wheels accept oem tpms or not.
Old 05-12-12, 08:30 AM
Nate008
Nate008's Avatar
^ I have TPMS in mine
Old 05-12-12, 09:23 AM
obby
obby's Avatar
Vossen recommend a +38 for the front but i guess everybody when with a 32 for a more flush fitment.. even with a 32 there's still a big gap from the fender.
Old 05-12-12, 10:01 AM
Evil Teo
Evil Teo's Avatar
I didn't know they had different offsets?
Old 05-12-12, 11:04 AM
obby
obby's Avatar
yea, there's two different offset you can go with.. i have a +32
Old 05-12-12, 11:06 AM
obby
obby's Avatar
i just added a 15mm spacer in the front so that it matches the rear. without the spacer, the front look so sunken in compare to the rear.
Quick Reply: Voseen CV3
