IS-F shopping...
I've heard of the right side pulling issue more so than the water pump. Some had it worked on under warranty, and I believe there are a few threads that describe re-alignment to decrease or eliminate premature tire wear. I would think wheel pitting from brake dust might be a concern if some have not checked out their wheels for some time. Best of luck in picking your F!
If you hold on to the seat (bottom part) and give it a push upward, It will rock back and forth. At first, dealer thought it was something loose, they tried to tight it up but nothing help. So they decided to replace the seats and the issue is fixed.
