Installed, F Sport rear sway bar.
I recently bought the F-sport rear sway bar with both bushings off another member with an IS350.
I am planning to install in on my 09 ISF.
Is it a direct swap with the original rear sway bar?
I read somewhere that on certain IS models, you also need bushing brackets?
Thanks.
Thanks.
Reading about this Fsport sway bar ...I guess it's a must to change on my 08 ISF.
Can you confirm that no need to buy the front and rear set....only the rear?
Is this the par number: P/N PTR0253080
Anything else needed to fit on 08 ISF?
Thanks
Thanks
just reinstating what you said lou, went the same route as well but im getting figs endlinks as mine just went
Posted from ClubLexus.com App for Android
Originally Posted by lowrideraz
The ISF front sway bar and the F-Sport front sway bar are the same OD, but the bushings are different.
Lou
Quote:
Originally Posted by Evil Teo
there is no benefit from installing the front as they are the same diameter as the stock ones.
Let's see, are you saying something different
Lou
Lou
Lou
^^^^^^You must have missed my post #10 on the preceding page![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Lou
The rear F-Sport bar we have been using was PN PTR02-53080, it's the old F-Sport Kit for the IS 250 AWD, and was never recommended or advertised by Lexus as being compatible for the "F". A number of folks, noticed it had a larger diameter than the Rear F bar, and thought it would fit. But again, it was never intended by Lexus to be used on the ISF.
Lou
Lou
SeanIS350
01-29-24 05:32 PM
