Sikky Rear Sway Bar Group Buy
Hey guys.
There is currently a group buy going on for the Sikky rear sway bar for our car.
The bar comes with 3 adjustable stiffness settings and would be a very noticeable handling upgrade.
Even an upgrade from the f sport bar too,![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Check it out:
https://www.clublexus.com/forums/clu...group-buy.html
Is nice
Check it out:
Is nice
I cannot speak from experience, but I read other testimonials on the forums and sure the Sikky sway bar is "better" than the f-sport, but everything is relative.
In comparison, (on paper) it's better, will be stiffer, my F is a street dd, but I wouldn't hesitate to choose Sikky
Over f sport.
If you search, you should find some reviews on it.
Over f sport.
I've always been told that sway bars are a crutch for improper spring rates, since they are a compromise. You tighten up the rear end, but you lose the benefits of having and independent rear since you are forcing the wheels to be one unit.
My thought is that if you need a heavier sway bar, you might want to look into different springs first.
I installed my F Sport Rear Sway bar a month ago...there is really a difference. the car seems more flat to the ground and when turning. also if your are running wider tires and wheels the sikky sway bar should benefit you. if you are on stock wheels and tires F sport is more then enough.
I had a Stillen rear sway on my G35 with the Eibach Pro Kit - absolute night and day difference - the car felt like a go kart in the turns. If I can get the suspension to immulate my G on this F I will be very happy. I'm gonna make sure I do the suspension mods one part at a time so I can dial it in as I go and know what is working and what is not.
are you talking at the track?
I have an '11 (same suspension) and had DRAMATIC body roll in turns at the track until I had my sikky sway bar (& Tom's chassis bracing/shock tower bar) installed..... Now it definitely is flatter in the turns....
