Which Wheel for track duty?
#46
juan, yes they will fit no problem.
#48
So here's the pics of the TSW Interlagos I got instead... Definitely not as sexy as the Enkie's but they were cheaper at least.....
SPECS: 18x9.5 +40 offsets
Since the Hankooks are unavailable, I ordered some Nitto NT01's (they are based off the Toyo RA1's but with stiffer sidewalls and updated tread pattern) they supposedly last longer than most R-comp tires and also have a good reputation for heavy cars...
SPECS: 275/35/18's
Also got some Rays Engineering extended Lug nuts in anodized blue.
Pics below
SPECS: 275/35/18's
Pics below
#50
Well, I got PF01's 18x9.5 +45mm and ordered some NT05's (265x35x18), I know they'll fit on the rear, but want to try the front first before I go with 265 all around. This thread has some great information
#52
I burned through a set of Hoosier R6 285/30/18 square last summer. 265's will not be an issue. This summer I will be going with a set of 275/35/18 Hoosier R7's. Apparently the R7 lasts longer, wears more even and sticks more. I can't want to try them out.
#53
That will not be an issue. I just bought the exact same wheels and I'm going to mount 275/35R18 Toyo R888 tires on them.
#54
Once I rip through 265's I'll definitely step up to 275 and maybe 285 if it is not an issue. Sorry for hijacking and thanks for all your answers!
#55
That is good to know, really and honestly. I couldn't get a concrete answer in regards to the wheel size I should go with, but I pulled the trigger on 9.5's. I'm suppose to get the 2 tires tomorrow and going to try it out, but if you guys are saying it wont be an issue at all in front, I may as well order the other set of 2 tires.
#56
If you consider 285mm in the future just realize that those running a square 285mm setup are running much shorter tires than stock. Close to stock height would be 285/35R18, and to my knowledge nobody has run this size on all 4 corners. It might fit, but I doubt it without trimming...especially if lowered.
#57
Sorry for bringing back the old thread!
Does enkei RPF01 18x9 +35 clear the front calipers of the ISF? I'm thinking of getting a square setup too. Is anyone here running Enkei RPF01 wheels?
GetUrWheel
Club Lexus Vendor Marketplace
107
08-10-18 01:18 PM
