TPS and RPM cables to connect Zeitronix ZT2
Hello,
Im in the process of installing a Zeitronix ZT2 wideband in the F. For dataloggin purposes I need to connect the a TPS and RPM cable to the Zeitronix unit. Does anyone know which is the easiest way to get to these cables.
Thanx.
Thanx.
Obby and MRxSlayX - Thanks. I thought they were also comming out of the ECU. Now i need to find out which are the cables.
968187isf- its for monitoring purposes and for my failsafe switch for my Nitrous Install. :-)
check if Apexi or greddy have a ecu pinout for the IS-F for the AFC or the Emanage ultimate... that's the only thing I can think of, doesn't seem to be a huge technical crowd here like the supra forums
Im going to take a look at my car later today. I think that off of the Throttle body the wire is black and dark green, but im not 100% sure until I check.
zazzn - thanks for the advise but unfortunately there is nothing there.
MRxSlayX- Thanks. Im starting to do the install today and this is the only two pieces missing of my install.
8speed
IS F (2008-2014)
807
04-24-09 07:44 PM
