MotoIQ evaluates Sikky Rear Sway Bar, Figs Lower Arms and Project Mu Rotors and Pads
We have been working on our IS-F!
http://www.motoiq.com/magazine_artic...-and-pads.aspx
We will be dyno testing some of Sikky's headers soon.
Read more about our Project IS-F here!
http://www.motoiq.com/projects/lexus...lexus_isf.aspx
Tech Info Resource
Let us know how the zero front toe works out. I just had mine measured after I finally arrested the inside edge wear (and I suspect I was toed in too much as the outer blocks were wearing much faster) and it was set to 0.22" toed in static. While it was on the rack, the tech did a simple simulation - he pushed outward on the front of the front wheels and took out half the toe I had dialed in. Just basic arm strength, nothing too intense. So we agreed to try it at 0.06 on each side - total 0.12 toed in. I have a feeling it will work well and finally get me balanced wear on the front.
I like the Project Mu rotors! Cheaper than OEM or OEM retail?
0.22" is way to much toe in for any conditions. With that much toe in the car will crab around under braking and not turn in well. For track use you want to have something like 1/8" toe out. That will provide better turn in and less rolling resistance as it counters camber thrust.
I just set the toe at zero mostly to reduce tire wear.
Tech Info Resource
My previous setting was zero toe. I got inside edge wear with street driving. I'm toed in ~1/8" now and expecting dynamic toe at zero while street driving. So I'll be interested to see what happens with your settings, especially if your results are similar to mine.
Tech Info Resource
I am trying to talk Sikky into making a front bar as well.
The car sticks like crazy!
Tech Info Resource
I still want to run a square 285/30/19 or 285/35/18 setup. I bet it would cure the whole understeer issue pretty easily. Track setup has to be 285/30/18 - it's the most economically available setup for track tires, and we know it works for R6's on Enkei PF-01s.
What's your current ride height? Stock -12mm or so? Curious where you get -2.0 for camber. Also curious if you've modeled the suspension yet. I haven't taken the time to do it, but would love to know where optimum ride height is from a camber curve perspective.
Do you think the 285 will fit in front? The car sits about 1.5" lower than stock and the gain in camber is from the lowering.
Since this is not a race car I did not bother to model the suspension like I do for a client. KW's base calibrations are normal pretty good so i just trusted them.
I am probably going to use Fig's upper arm and I am debating if I should use the super pro bushings. I don't want to mess up the NVH too much but it would be interesting to see what this car's potential is.
Superpro bushings usually have pretty good NVH for a urethane bushing.
MK4Sup_isF
05-17-16 10:46 AM
LexusISF19
11-26-14 07:53 PM
