Iss forged rmi scoop owners!
I installed my RMI scoops about three days ago and I noticed my horn sound changed.. The F used to have a bada** mean horn, but now with the scoops installed, it sounds like a horn coming from a '97 camry.. Any other RMI scoop owners notice this? Or did I do something wrong. thanks!
__________________
![](https://www.clublexus.com/forums/signaturepics/sigpic167102_16.gif)
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
sounds like the grounding issue... I had to grind away some of the paint off the scoops where the bolts/washers are to make a good contact so both horns work.... if only one of them are working it sounds "weak"...
I installed my RMI scoops on Friday and had to sand a little paint off as well. I put some blue painters tape spaced about 1/4" around the hole to so didn't scratch the rest of the scoop and grabbed a sheet of sand paper I had sitting on my work bench. I sanded just enough off around the bolt hole to see a uniform circle of metal all the way around.
I did this to both scoops to make sure they both worked properly.
Theres a link in the RMI thread that mentioned you would have to sand alil bit for the horns to work properly... No biggy just have to get your hands alil dirty LOL
no clue why I didn't bother to search.. LOL! thanks guys.
__________________
Orange County, CA
Orange County, CA
Just for informational purposes:
Thread regarding the review of the ISS Forged RMI Intake Scoops:
https://www.clublexus.com/forums/is-...review-15.html
Thread of the install of the ISS Forged RMI Intake Scoops:
https://www.clublexus.com/forums/is-...tructions.html
* Mentions in the beginning of the install, the issue and fix regarding the horns.
Hope this helps bro! Have a good one!
The sound change is normal.. You have to flip the horn for the install and now that u have the scoop in front the sound will be muffled a bit. mine sounds "wimpy" too. I laugh at it whenever i use it .
Then you likely have one horn not grounding correctly as mine sounds the same as previous once grounding issues were fixed.... Only had the wimpy sound when one horn was only working.
thanks! I did exactly this and it worked perfectly, no sanding necessary. fhew!
__________________
Orange County, CA
Orange County, CA
__________________
Orange County, CA
Orange County, CA
