little rubbing front axle when reversing ( gear R )
Are you positive the rear is +22? I thought that aggressive of an offset would stick out more.
I wish people here would also post their offsets along side the rim size. You can take a 7" wide wheel and still make it look aggressive if made in the correct offset. Not that I would do that, but just pointing out that wheel offset is actually what matters most(if wanting a flush or aggressive look is your preference).
What are the widest tires i can run on 19x8.5 F +30 19x10.5 R +38 on springs with minimal modification. Also whats the most popular springs people are running was thinking Swift or H&R.
^ yes I run 19x8.5 +24 front 245/35 19x10 +23 rear 275/35 and only had to roll the rear fenders. I'm on stock suspension as of now. I'd like to have my wheels rebuilt to have the front lips a inch towards the fender lip and a inch wider, the rears only a inch wider on the inner lip.
