Aftermarket ISF wheel thread
Old 04-04-15, 09:17 PM
  #211
jleonard71
jleonard71's Avatar
Justin, did you go to Boise State?? LOL.
Old 04-04-15, 09:52 PM
  #212
KSLAM
KSLAM's Avatar
Originally Posted by CalitriSC
Ok here's a bad phone pic, better in person of course.
Anyone know what wheels he was running?
Old 04-05-15, 12:17 AM
  #213
Fivepoint0
Fivepoint0's Avatar
Think they are Linea Corse 888s, was the only set I know off.
Old 04-05-15, 05:56 PM
  #214
scENFORCER
scENFORCER's Avatar
Originally Posted by USBISF
Here's mine on TE37s
19x9.5 / 19x10.5
My favourite in the whole thread
Old 04-05-15, 07:45 PM
  #215
jleonard71
jleonard71's Avatar
Originally Posted by Justind27
^ yes I run 19x8.5 +24 front 245/35 19x10 +23 rear 275/35 and only had to roll the rear fenders. I'm on stock suspension as of now. I'd like to have my wheels rebuilt to have the front lips a inch towards the fender lip and a inch wider, the rears only a inch wider on the inner lip.
How in the world are you running 19x10 +23 with 275/35 in the rear without rubbing?? I have 19x10 +42 with 295/30, so the tires are 10mm wider on the outside but the wheel has 19 more offset, so the outer edge of my tires stick out 9mm less than yours. Plus my tires have a diameter of 661mm compared to yours which are 675mm - so they are 14mm taller. I had my fenders rolled and I still rub on big bumps or dips in the road, and there's no way in hell I could get away with another 9mm, plus have a larger diameter tire, and have it remain remotely driveable.
Are you sure about those specs? Or do you have adjustable camber arms running an addition -2 or -3 degrees of camber? That's the only way I could see that setup possibly working.
Old 04-05-15, 07:50 PM
  #216
Justind27
Justind27's Avatar
No all stock suspension, the rears rub going +50 mph with bumps in the road. Yes I'm positive, the stickers were on the wheels when I purchased them.
Old 04-05-15, 07:52 PM
  #217
jleonard71
jleonard71's Avatar
What brand & model of tires are you running? That could be the difference because tires can vary +/-1" in width (25mm) from brand to brand in a given size.
Old 04-05-15, 08:56 PM
  #218
Justind27
Justind27's Avatar
Federal 595 ss
Old 04-05-15, 08:59 PM
  #219
Justind27
Justind27's Avatar
Nope, born/raised in western WA. Joined the army after high school, got Calvary/veteran window decals. Only college I've done is certificate programs for being a composite technician for airplanes mostly but I'm currently a fuel cell technician on te 787 dreamliner
Old 04-07-15, 03:02 AM
  #220
spdrcr771
spdrcr771's Avatar
Originally Posted by digger08
^^^^I believe the front spokes will not clear the brakes.
Digger08
They will clear the brakes. I have a set I just took off my SC. I fit the driver front rim on and set it on the ground. Just didn't look right to me. So I posted them for sale. Might look better with a drop!
Originally Posted by Vervish
I can't find one photo of an ISF with those wheels on it..
I guess maybe I should put them on my F & post a pic!
Old 04-07-15, 07:14 PM
  #221
FNSSESPORT
FNSSESPORT's Avatar
[QUOTE=spdrcr771;8989538]They will clear the brakes. I have a set I just took off my SC. I fit the driver front rim on and set it on the ground. Just didn't look right to me. So I posted them for sale. Might look better with a drop![QUOTE=spdrcr771;
That's weird, I have a set of 19in. F-Sport wheels and was going to try them on my F to see what they look like. I started with the rear, and right away the rear spokes wouldn't clear the brake caliper.
-R
Old 05-09-15, 10:05 AM
  #222
nysupraman
nysupraman's Avatar
I am looking for a set of wheels which are 20x9 +35 and 20x10.5 +45 on my IS-F. I wanted to do a very conservative drop, still deciding on whether I should get springs or coils? What size tires should I purchase, and with say maybe a 1" drop do you thing I would need any fender mods or will be pretty flush?
Old 05-09-15, 01:50 PM
  #223
Meraki Autoworks
Your #1 Lexus Vendor
CL Vendor - Starter
Meraki Autoworks's Avatar
Rolling your fenders will be a good idea, and with that setup you can run a 245/275. & coils for sure so you can adjust the height.
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Old 05-10-15, 08:34 PM
  #224
nysupraman
nysupraman's Avatar
Thanks! 245/35 and 275/30 would do? I would hate to have a thinner aspect ratio or have to stretch tires!
Old 05-26-15, 10:34 AM
  #225
samjones
samjones's Avatar
guys, I got these dpe 19x8 +45 front & 19x9.5 +45 rear. The front has only been lowered, and I m looking to get spacers. Do you guys think 15mm h&r would do fine without rolling fenders or should I do 15mm front and 5mm rear? thanks <br/>
Quick Reply: Aftermarket ISF wheel thread
