Aftermarket ISF wheel thread
#458
[QUOTE=nickj718;9863397]Can a someone verify if these will work
Front: 19x9.5 +40
Rear: 19x9.5 +40
Front Tire: 245/35/19
Rear Tire: 265/30/19
The car is dropped in the front only on swift springs. Im pretty sure they will be ok[/you
You should be fine even with 255/35/19 front and 285/30/19 rear. Or you can square the tires up to 275/30/19 for the both front and rear. 265/30/19 is a bit shorter in OD and you still have some rooms in the rear
Front: 19x9.5 +40
Rear: 19x9.5 +40
#461
you should be fine for the front and in the rear I think you is OK too, but maybe its slightly rubbed if so just get fenders rolled.
#463
anyone running 19x10 and 19x11's? got my VSXX re-barrelled and will look to get some rubber soon. IS-F still on stock height, thinking about running 255/35/19 fronts and 285/30/19 rears. I forgot what the offsets were but I believe the fronts are R-Disk and rears are O-Disks.
