A 265 on a 10.5 wheel? That's not a performance fitment at all.
I know it looked very off to me. Also with saying he had no fender modification needed doesnt seem right either.
Originally Posted by flowrider
^^^^Can you say S T R E T C H E D
Lou
Yeah Im not a stanceboy, just wanted to get other's opinion on it to make an informed decision.
Originally Posted by FFM
Even 275 on a 10.5 was a bit too stretched for my liking. And it was a wider than average 275.
yeah I am wanting to go with a wheel that wouldn't require too much fender modification. 9.5 +35 from what I am being told by others who have ran that size, are saying very little to none in regards to fender modification.
Originally Posted by Jwconeil
275 on a 9.5 inch wheel is perfect for function, and looks great in my opinion.
Yeah the size tire i want to run. With 18 X 9.5 on 275/35/18 Michelin Ps4's ill not only have a slightly quicker ride (due to lighter wheels) but also will be able to rotate tires and potentially have them last longer lol. Michelin Ps4's at 18's are almost a whole 5-600 cheaper for all 4 compared to 19's .
^^^^That's what is recommended:
Lou
That is the size tire I want to run. Except a square set up so I can rotate tires for longevity. I appreciate the information!
Yeah the size tire i want to run. With 18 X 9.5 on 275/35/19 Michelin Ps4's ill not only have a slightly quicker ride (due to lighter wheels) but also will be able to rotate tires and potentially have them last longer lol. Michelin Ps4's at 18's are almost a whole 5-600 cheaper for all 4 compared to 19's .
275/35/19 in the front will rub. You’ll have to run a 30 series tire to make it fit, and a 30 series in the front will ride harshly (AMHIK). A 35 mm offset may also rub depending on height and tire. A safer bet is 45 mm, which is the most popular option for function that I have seen. I’ve seen most guys report no rubbing with a 38 or 40 mm, but I’ve seen some report rubbing, so I just went with a 45. Maybe they can chime in on their experiences.
i fat fingered it. I meant 18. I actually found someone running these same wheels and specs and he had a mild fender roll to make it work. Fronts he said was fine with no issues.
Originally Posted by Vervish
Assuming you meant 275/35 18s - they will fit fine. I run 275/35s on 18x9.5 et 45 with no rubbing on stock fenders.
Yeah i meant 18’s. Fixed the typo lol. I was able to find an ISF owner with the same specs/wheels and he just had a mild roll on the rear with no issues in the front. I do plan to lower the front 0.5-1 inch in the future but ill tackle that after i have wheels.
heres a photo of his setup be sent to me for reference.
Hi guys, this is a set of OEM GSF wheels that I painted graphite gray. 19x9 up front with 255s and 19x10 in the rear with 275s. Lowered on KW V3s, fenders rolled and slightly pulled in rears only. The front is running 15mm spacers, I rub up front in dips so I will probably switch to 245s next season. with a local buddy's RCF
I currently have a 255 on my oem 2013 9.5 inch rear wheels because I had them laying around, and I don’t like it at all. Way to much stretch, leaving rare wheels unprotected.
If I used those wheels more often, I’d put a wider tire on it.
Looking for some opinions on a set up that I'm looking at .
20 x 9.5 f +32 /. 20 x 10.5 R + 32.
Tire size is 245 35/ 285. 30. I'm currently stock suspension would like to get some coilovers in the next year . Do you think it should work . I've noticed that most are have upgraded but decided to stay with 19s. I like the look of the 20s but open to 19s.
I'm looking at around 2k with tires and new sensors. He also said that he I'll roll my finders if needed. I just want make sure it's going to work before pull the trigger.. thanks guys
