Aftermarket ISF wheel thread
#721
I wanted something that kept the oem size 19’s but lighter then our oem rims. Found the Advanti Hybris wheels and at 19 pounds each I couldn’t complain. Specs below..
front 19x8.5 30et (255/35/19)
rear 19x9.5 40et (285/30/19)
Rear quarter panels needed a roll and pull.
Your opinion on whether 275/30R19 tire on those rear wheels (40mm offset) would need rear quarter panel work for clearance? Figuring typical 275/30R19 is 10mm narrower and 0.2-0.3in smaller diameter than 285/30R19.
#722
Approximately how much lower than stock height in the rear?
ChpEng (01-23-21)
#723
265/30r20 Front?
Looking for advice. Didn't see anyone running this tire size. I'm at stock height running 20's. The front wheel is a 20x9 w 32 offset. I had 245/35's but they rubbed a little so I went down to a 245/30 and that was way to small. Looking at either a 255/30 or 265/30 on the front. Just want to know if anyone has run a 255/30 or 265/30 in a 20 with the same offset. Thank you.
The following 6 users liked this post by MMI:
ChpEng (03-27-21),
forget2pee (08-18-21),
JT2MA71 (04-11-21),
MileHIFcar (03-27-21),
mk416 (03-27-21),
and 1 others liked this post.
#725
#726
Yes stock suspension and no fender mods. No rubbing except front right catches the grille vent in the wheel well liner when reversing with wheel turned full lock to the left. This can be fixed with a heat gun to gain more clearance.
#727
#728
Read through this thread, tons of great information. Just want a quick gut check. Found a deal locally on some new SSR GTX01s. Its a 18x9.5 +40 square set up. My BIGGEST concern is being able to have a nice square set up with no fender/quarter panel mods. Looking like a 265/35/18 tire will be ok? Or should I go with a 255/40/18?
Also, I am running the HKS Hipermax coils but all i've done is drop the front a smidge so its level. Thoughts?
#729
Hard to say for 100% though... lots of factors that come into play, especially since you are lowered on aftermarket suspension. Wouldn't stop me from moving forward though.
I'm running 18x9.5 +45 with 275s square lowered on Ohlins and it does rub in the front some but not bad enough for me to be concerned. 265s would rub even less.
BertoISF (07-22-21)
#730
You may have some slight rubbing in the front but I don't think it will be anything to worry about.
But you dont rub rears at all? (Someone not into cars would think that question is wierd)
#731
I have the same suspension and only lowered 3/4 inch in the front and 1/4 inch in the rear with 275/35 18x9.5 +35 with slight rubbing in the front at full turn lock and it did rub on slight bumps in the rear until I had the fenders rolled flat. Now it only rubs in the rear on really hard bumps.
265 you shouldnt rub at +40 offset but it also depends on what tire you are running. Some 265 tires run as wide as other 275 tires
#732
Some more nosy questions....Do you know if it rubs on inner or outer shoulder? Only at full lock, or sometimes less than full lock if on a bump? What tires are you running? I am getting the impression vs other observations that 275/35R18 on 18x9.5 ET45 is a close fit up front...
ChpEng (07-27-21)
#734
Howdy guys,
Looking at winter set. Have pre-existing 255/35/19 Nokian Hakka tires.
Wondering if Id fit with 19x19.5 et35 aftermarket wheels square set up.
Lowered on coils.
Thanks
Lowered on coils.
Thanks
#735
255's on a 19.5 wide wheel should be pretty interesting
assuming you meant a 9.5 wide wheel, tire will fit on the wheel (255 will have a slight stretch on 9.5 wheel) and a 19x9.5 +35 with a 255/35 should be fine in the rear and probably be possible in the front... and while I say it will all fit, I wouldn't call it an ideal winter set up. But I'm in California where winter doesn't happen, so what do I know.
If you're the type of person who is against fender rolling or modifications and cannot handle any rubbing, then no... it won't fit... bc you'll prob have some rubbing in the front.
