Aftermarket ISF wheel thread
Old 03-26-24, 11:19 AM
  #811
DanceEng
DanceEng's Avatar
Would 19x10” +39 fit on this car with a square setup at stock ride height? Thinking of getting dinans. Let me know if there are issues with these. Main thing that's putting me off is that they seem heavy
Old 06-15-24, 11:15 PM
  #812
FforFun
1st Gear
FforFun's Avatar
Default a question
Originally Posted by Murph145
^ cant go wrong with the Advans nice light weight rims!
Here is my contribution
ADV.1 10 Track function
20x9 Front 245/30/20
20x11 rear 295/25/20
lowered on tein springs no rubbing or fender modificaiton required
Attachment 430924
Love these rims, what offset are they?
Old 07-15-24, 08:28 AM
  #813
Isfisaiah
8th Gear
Isfisaiah's Avatar
Default Help with wheel setup
Hello, I have a 2008 Lexus isf stock I was hoping someone can help me knowing if this wheel setup would work on it. Any help would be nice
Enkei Ts-5
18x8.5 38 front
255/40/18
Backspacing: 6.25
Offset: +38
Wheel Diameter: 18
Wheel Width: 8.5
Hub Bore: 72.60
Load Rating: 1543
18x9.5 38 rear
275/35/18
Backspacing: 6.75
Offset: +38
Wheel Diameter: 18
Wheel Width: 9.5
Hub Bore: 72.60
Load Rating: 1521
Old 07-17-24, 09:21 PM
  #814
isam250
isam250's Avatar
Enkei Ts-5
18x8.5 38 front
255/40/18
Backspacing: 6.25
Offset: +38
Wheel Diameter: 18
Wheel Width: 8.5
Hub Bore: 72.60
Load Rating: 1543
18x9.5 38 rear
275/35/18
Backspacing: 6.75
Offset: +38
Wheel Diameter: 18
Wheel Width: 9.5
Hub Bore: 72.60
Load Rating: 1521
yah you’re good I’m on swift springs 18x9.5 +38 265-35-18
The following 2 users liked this post by isam250:
Bechtold (07-18-24), inovashn (07-18-24)
Old 07-18-24, 04:09 AM
  #815
Isfisaiah
8th Gear
Isfisaiah's Avatar
love the setup, but I wanted to see if it would fit on stock suspension and all. But I also heard about difference in driving and etc.
Old 07-18-24, 12:53 PM
  #816
MMI
MMI's Avatar
Enkei Ts-5
18x8.5 38 front
255/40/18
Backspacing: 6.25
Offset: +38
Wheel Diameter: 18
Wheel Width: 8.5
Hub Bore: 72.60
Load Rating: 1543
18x9.5 38 rear
275/35/18
Backspacing: 6.75
Offset: +38
Wheel Diameter: 18
Wheel Width: 9.5
Hub Bore: 72.60
Load Rating: 1521
You will most likely rub on all 4 corners with those specs.
ChpEng (07-18-24)
yishin
IS F (2008-2014)
22
10-15-22 03:25 AM
Fischy13
IS F (2008-2014)
91
09-23-11 10:45 PM
8speed
IS F (2008-2014)
45
11-09-08 07:50 PM
Supraman16
IS F (2008-2014)
09-28-08 02:04 PM
Quick Reply: Aftermarket ISF wheel thread
