EGR Delete - has anybody looked into this?
Old 07-11-12, 06:41 PM
mishkinm5
mishkinm5's Avatar
Default EGR Delete - has anybody looked into this?
Ok guys i just wanted to throw this out there. I am currently trying to develop a complete egr delete for my isf. I think there is just way to much clutter in the engine bay. I did this on my GTR and was very happy. This would not trigger your cel as i would be using resistors to simulate the egr units. I am not going after performance more esthetics. I am aware of the fact that this might yield a few ponies. I will be trying this out in my personal f. Has anyone done this already?
Mike
Old 07-11-12, 06:48 PM
LiLS
LiLS's Avatar
i dont udnerstand waht this is o_O
Old 07-11-12, 07:16 PM
MisterSkiz
MisterSkiz's Avatar
http://en.wikipedia.org/wiki/Exhaust_gas_recirculation
Old 07-11-12, 08:00 PM
ming15237
ming15237's Avatar
Mike
And the point of this would be to what? You cant even see the egr valve when the engine cover is on. And between you and I... There would be little to no performance gains with this delete as the egr valve is ONLY open under partial throttle applications at cruising speeds where the vehicle is producing significantly less than 100hp.
Old 07-11-12, 08:01 PM
DCoolBeans
DCoolBeans's Avatar
I've done this to ALL my fuel injected motorcycles but would be weary to do it to my Lexus which is still under warranty
Old 07-11-12, 08:11 PM
zapa
zapa's Avatar
@DCoolBeans
I think you can kiss your warranty good bye with the addition of headers.
although you might be able to scare the small service rep with your huge muscles.
Old 07-11-12, 08:20 PM
DCoolBeans
DCoolBeans's Avatar
Originally Posted by zapa
@DCoolBeans
Hahaha That was a good laugh...I needed that.
Um duh, I got the headers in stealth black.....so that means they can't see em
Old 07-11-12, 08:28 PM
aWorkOfArt
aWorkOfArt's Avatar
Searched the forums and found this:
https://www.clublexus.com/forums/ls4...gr-delete.html
I understand that they are totally different cars, but still the same concept should be applied since our cars have VVT-i... Either way, good luck with your research and keep us posted!
Old 07-11-12, 09:30 PM
UCrazyKid
UCrazyKid's Avatar
No interest from California, no EGR = no pass smog test
Old 07-11-12, 10:20 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,010 Likes on 2,429 Posts
What EGR? The 2UR-GSE doesn't have one. Toyota uses cam timing to do this now. It's way easier to do with software than it is to do with hardware. EGR valves went the way of the dinosaurs quite some time ago.
Old 07-12-12, 06:47 AM
mishkinm5
mishkinm5's Avatar
Our engines do have a more complicated form of egr. They are located towards the back of the engine by the firewall. They have multiple coolant lines and a single two pin plug. I have done the same mod to my gtr and love the results.
Old 07-12-12, 08:35 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
No there isn't anything specifically used for EGR besides the cam timing. Nothing. Nowhere in the service manual or the new car features is there any mention of EGR control outside of cam timing. Just because Nissan decided to do it their way does not mean Toyota is doing the same thing, especially when you consider EGR on a boosted engine vs. an NA engine.
There is absolutely NOTHING on the 2UR-GSE you can remove to disable EGR.
The thing you are referring to with multiple FUEL lines and a connector is the purge system for the evaporative emissions.
bbong (06-07-18)
Old 07-12-12, 11:21 AM
Juanca
Juanca's Avatar
Actually these headers were installed by a Lexus dealer.
@DCoolBeans
Old 07-12-12, 12:30 PM
zapa
zapa's Avatar
but does that mean they will cover it under warranty. If so i will get my lexus dealership to install mine for me instead of a more trusted performance shop. My only concern is that my lexus dealership is going to want to charge me to hell.
Old 07-12-12, 01:48 PM
RCB
RCB's Avatar
Lobuxracer is right, most cars use variable cams to avoid the need for EGR valves now a days. I'm surprised GTR even uses an EGR valve.... is that really true?
Quick Reply: EGR Delete - has anybody looked into this?
