Voltphreaks Lithium Battery Install part of the F diet :)
Glad to have Cali in the rear view. Miss the weather, but that's all...
The unfortunate thing is this makes the cross weights even worse. The car is biased to the driver's side with the stock battery. Removing weight from the passenger's side means the driver's side just picked up a few more pounds on the left front tire.
We really need to figure out a total strategy to lose weight AND fix the l/r balance problem from the factory.
And yeah, the battery is super light and super expensive compared to the conventional options.
The only thing even close would be to replace the steering column with a non-telescoping unit from an IS250. Adding something back isn't really a good goal unless you have a minimum weight you have to meet. Everything else in terms of l/r balance is pretty difficult.
