Minimum requirements?
Hi,
I'm in the market for some wheels and have read a lot of threads discussing wheel fitments. I'm a noob at this and dont really know what to look out for when buying a set of wheels.
According to the Lexus site the Stock wheels have an offset of 45 F and 55 R, and on some other sites it says the requirements are "Higher offsets". So, does anyone know the minimum/maximum offset requirements for the ISF.
Any help would be appreciated.
Thanks
Thanks
I remember seeing ISF with as low as 30 offset in the front. I could be wrong tho. And camber makes a difference too..
I don't like hellaflush+hellacambered look but if you do, offset can go even lower.
Good thread. I too am sort-of shopping for wheels (the right ones with the right deal pop up and I will jump on it) but I don't want to do any fender work or bumper tab relocation, and I definitely don't want any rubbing. I want to stick with 19" as opposed to going with 20s as well. That said, some of the wheels I like are wider than the stock wheels in the back (9.5 or 10.5 instead of 9") and slightly wider in the front as well 9" instead of 8". I'd like to run something maybe 8.5f, 9.5r with offsets in the mid-upper 30s, but I'm unsure if that will fit with or without lowering the car.
right now im running a 9.5 front and a 10.5 width on the back but idk wut my offsets are all i know is that its the most offset weds sa55m makes them in and damn my rims are poking like a ****..i like it but just wanna know for my next set of rims..i already pulled and rolled my rear fenders so i know i can go a little more then stock but i just wanna know the standard b4 the roll and pulled
The weds are one of the best looking rims by far, and this is where the min/max requirements for the ISF would help in making the right choice.
When i filter out rims on tirerack.com for the ISF the weds are unsupported. When i choose them it says that "these rims will not fit the Lexus", however a couple of members out here have the weds on the lexus.
So anyone with any info about the min/max requirements, please chime in.
