Stock Rear sway bar vs. F-Sport Rear Sway bar pics
If you close to Longo Lexus, they have $75 coupon of non-special work.
doesn't have to be a better lap time just proof that it enhances the car... not inhibit it.
i mean a cheaper solution would be just decrease ur psi. for more grip,
i mean in my 350 i feel like i can go 10mph more on the same on ramp with the f sport rear sway bar,
Unfortunately, no one has done timed testing on the rear sways. Honestly, the car needs more front spring before you mess with the swaybars. Inside rear wheel lift is a big problem with the F at a road course, AMHIK.
Got my F-sport rear sway bar installed on Saturday. It literally took me 15 minutes in the garage to put it on. I'm pretty happy with the way the car feels when hitting some turns. I'd give it 2 considering the cost.
Agreed had mine installed last week. It does feel better in the turns.
Installed mine last saturday, there is a noticable weight difference to the new bar, much more stable. Haven't had a chance to play around with it too much yet though. Will let you know how it feels when I take it on the track
Yup, that's the one I checked the part# on a box. I installed mine on my '12, my dealer told me it will not fit since it's for is250awd but that's the one that fits ISF's.
BieberNutz (02-19-17)
no problem man, if you are planing to do it yourself and your F went thru few winters I would really recommend new end links. I was hoping of swapping mine when I did the install but the surface rust/ ball joint design, just made it impossible to reuse them, I was trying heat, lube, etc to take them off, in the end had to cut them off and buy new ones. My F was out of commission for 2 days until parts showed up, pain specially bc it's my daily. Good luck.
no problem man, if you are planning to do it yourself and your F went thru few winters I would really recommend new end links. I was hoping of swapping mine when I did the install but the surface rust/ ball joint design, just made it impossible to reuse them, I was trying heat, lube, etc to take them off, in the end had to cut them off and buy new ones. My F was out of commission for 2 days until parts showed up, pain specially bc it's my daily. Good luck.
supersonic (02-19-17)
