Not going to bash VJ but I want to put some input on the wider tires. Anyways the wider tires doesn't add much weight compared to stock...not that I notice anyway when I had my DW on. Traction in wet and dry improved and also my tread life increase due to the change in brand. The speedometer accuracy isn't that far off. If I remember a member pointed out that in 50k miles your losing 500 miles which isn't much. If you go PSS I suggest sticking with the stock size. If you go with another brand I suggest going wider.
This could be true, although It would be nice to see numbers from those who track their ISF's, to see if upsizing actually yields better performance.
it might be better if you use the square setup for track as mention by a couple of members on here. the wider tires would be better for street use in my opinion. the stock setup is ok for both.
