Low engine oil level ???
Old 05-01-16, 10:02 PM
blackisF08
blackisF08's Avatar
my car is going in Thursday to the dealer for a losing coolant slightly every couple months so i am gonna have them check this out as well. i will keep you updated once i get the report from them.
Old 05-01-16, 11:55 PM
kzlflash
kzlflash's Avatar
Originally Posted by 2URGSE
Do a complete oil change and make sure you go with a quality 5W-30 and OEM filter. 9.8 qrtz is what goes in there.
Check for leaks. If no leaks are present keep track of the oil level.
If you're still losing oil, it will be time for a leakdown/compression check on the engine.
Currently using the OEM filter along with Mobil 1 5W-30 synthetic. Mechanic fills 9.8 every time. I'll definitely get it checked for leaks on the next change.
Old 05-02-16, 12:05 PM
spdrcr771
spdrcr771's Avatar
Originally Posted by dLad
my light always flashed way too early....usually 2k in or 2500 into the previous change.....this happened three or four times. Once it was 1 1/2 quarts short. Once it was 2 quarts short. And once 2 1/2 quarts short. I asked the dealer WTF?!?!? They said that Lexus actually claims allowance to burning a quart per 600 miles. I thought it sounded fishy. But that's my experience. So basically the oil changes are done every 5k miles....So I always stopped in around 2k or 2500k (whenever the light came on) and they added the proper amount for free. It was a pain in the *** to have to go there double the time I should have.
P.S. They definitely changed the oil the right way and put in the right amount. I made sure of this after the first time it happened, then it kept happening.
My car does this exact same thing. Not sure about how other ppl drive their car. But I drive mine hard most of the time..
Old 05-02-16, 12:35 PM
fstpassat
fstpassat's Avatar
08 with 82k miles here and I have never had to touch the oil level.
Old 05-02-16, 06:48 PM
2URGSE
2URGSE's Avatar
I would check the dipstick daily if you drive it daily and keep a log with dates and the level on the dipstick.
Old 05-02-16, 08:30 PM
lolfunxion
lolfunxion's Avatar
Weird, I recently went 7k between oil changes because I was fighting the dealer about a service bulletin and they kept saying "wait until we resolve this before you come in for oil". Because of the extra 2k, I was religiously checking the oil levels to make sure I wasn't getting low with the few extra miles.
I never ever went below the top full mark, on my 2008 that had 85k when I just went in a couple of weeks ago for the change.
Seems people have had mixed results, I wonder what the culprit is...
Old 05-14-16, 01:19 AM
V8Lex
V8Lex's Avatar
After 3.5k miles I had to add a full quart on my 2011. Wasn't expecting S2k oil consumption levels on this thing
Old 05-14-16, 01:41 AM
idoke1
idoke1's Avatar
I never had to add any oil in my 08 as well. It's always on the FULL mark.
Old 05-14-16, 10:16 AM
j3ff
j3ff's Avatar
Just curious if you're running synthetic or not? It almost seems like half our members are burning oil. I'd be curious to know what your results are if you sent a sample to Blackstone.
Old 05-14-16, 10:47 AM
kzlflash
kzlflash's Avatar
Not the OP, but I'm running Mobil 1 synthetic. I do drive in manual mode 90% of the time, and usually stay at or above 3k RPM for freeway driving (which is 90% of my daily commute). I assuming the higher revs might be a contributing factor to my burn.
Old 05-14-16, 06:38 PM
2URGSE
2URGSE's Avatar
Could be how the various cars were broken in by the first owner, but that's just my speculation and I don't want to start "How to break in an engine" argument here.
I will just say that I followed the manual throughout break in and swapped the oil at 1200 miles, as opposed to 4,000 miles.
Old 09-19-17, 02:49 PM
clarionguy
clarionguy's Avatar
Does everyone only use synthetic?
I've used conventional 5w30 for 300000.
But in the last 100k I have noticed I have to add oil.
Now I have ppe headers and gesi cats. I cannot tell if I'm burning the oil or am running rich.
Also have the rr racing tune.
Wot a ton or smoke blasts out of my exhaust.
Before I had the cats on it was black. Now it's a lighter shade but I have no coolant lost.
Pcv? Pain to get at however.
Old 09-19-17, 03:16 PM
liquidtek
liquidtek's Avatar
Get the RR AOS?
Old 09-19-17, 03:32 PM
clarionguy
clarionguy's Avatar
Already have that too.
Old 09-19-17, 06:10 PM
Weapon F
Weapon F's Avatar
I DD my F the same way shifting between 3k and 4k, and when driving home at 1 a.m. in the morning if traffic allows I'm shifting even higher 5 to 6 days week. My oil is mobil1 synthetic as well. Something interesting to note when my hours were changed for a few months and I was working day shift and could no longer Drive aggressively I found that I didn't lose any oil. Once I switch back to evening shifts and my typical driving I went back to losing small amount of oil between changes.
Quick Reply: Low engine oil level ???
