Low engine oil level ???
#31
I DD my F the same way shifting between 3k and 4k, and when driving home at 1 a.m. in the morning if traffic allows I'm shifting even higher 5 to 6 days week. My oil is mobil1 synthetic as well. Something interesting to note when my hours were changed for a few months and I was working day shift and could no longer Drive aggressively I found that I didn't lose any oil. Once I switch back to evening shifts and my typical driving I went back to losing small amount of oil between changes.
#32
Mine used about 2 litres in 10000kms, I changed the oil to fully synthetic and 3000kms has not shifted on the dipstick try fully synthetic, and these cars need a very flat surface to check the oil cheers.
#33
Tech Info Resource
All engines burn oil. If the level doesn't move, you have fuel dilution or water dilution going on. It is impossible for an engine to burn no oil. If you have a really good ring fit, you'll burn a smaller amount, but there's no such thing as a ring that doesn't allow some oil into the combustion chamber.
#34
#35
#37
I have to add maybe 1/2 qt over my 10k mile oil change intervals??........I do have the RR AOS so I guess I burn some oil but next to nothing over the time interval
#38
As I stated earlier I do see a small amount of oil being burned off when driving much more aggressively I change my oil every 7000 miles. My oil has never dropped as low as OP.
Typical night driving home, as soon as I pulled out the gas station on the highway heading back home I notice PD, so I have to slow down for a little bit youll see his lights come on as he bagged somebody.
