Cruise Control Not Working???
How fast were you going when you tried to set. Also if you push the arm that has the button toward you it won't let you set it. I don't know if just my car is like that but whenever i push the arm toward me and let it go back to its normal position it won't let me set.
pushing the arm toward you cancels the cruise... To set it, I believe u push it down, to resume from previous cruise that was canceled, push it up... This is from the top of my head since I use it quite a bit on my morning commute...
Tech Info Resource
Does not work in manual mode. No idea why.
All of this is in the owner's manual. It's a pretty handy tool for understanding how to use the controls and indicators.
Tech Info Resource
Must be. If you can't set it in D, then there's something wrong somewhere. Probably pretty easy to troubleshoot with Techstream, and not so easy with basic tools. More than likely a loose connection somewhere.
My advice is to research which wiring the CC uses (I have no idea personally) and then see if anything of yours is loose at all. You may literally just need a jiggle of a wire to get it to work.
Another easy test would be to meetup with another local F and have them try your car to rule out human error. Either way you can still talk cars a bit and if you're on this forum them I suspect that's enjoyable to you as it is to us. And it would save you a dealer trip.
