One more (my last) wheel fitment question for the experts.
I'm at stock ride height, stock suspension on a 09 IS-F. Wheels specs are:
19x8.5 +38 front (225/40 tires)
19x9.5 +29 rear (255/35 tires)
I'm sure the fronts will fit without an issue, but it is the rears that I'm a little worried about. I really don't want to roll, pull and stretch fenders or dremel out fender lining to make anything work. Eventually I'd like to also lower my car a little bit and maybe even run a wider set of tires, but I'm thinking with those offsets, I might be stuck with the stock tire sizes unless I want to mod my fenders.
Anyone have experience running wheels this size, and if so, what tires/suspension are you on?
Thanks
Thanks
I can't see why that would be a problem - I'm running
20x9.5 + 43 fronts and 20x10.5 +45 rears with 255/30 fronts and 305/25 rears. The rears DO rub under big bumps or weird articulation but the fronts have no issues at all.
Thanks for the information. You're on stock ride height, correct? Do you have any fender work done? I just played around with the numbers a bit, and I'll basically have the same spacing as if someone was running a 10.5 +43 in the rear, virtually identical to what you have, except I won't have nearly the width of your tires. Do you have a picture by chance?
Thanks for the link. So according to that calculator, my rears will stick out an extra 32mm or 1.25" from where the stocks sit in the rear. I think I will definitely have some issues if I try to lower the car or run a wide tire, but at stock ride height and tire size, maybe I'll get away with it without rubbing (btw, a 255 on a 9.5" wheel won't have to be stretched).
I have side pictures, but no pictures of the fitment really - this is the only one that shows it a bit.
I did roll my rear fenders, but frankly it's not quite enough to tuck the 305s, when the 305s are sufficiently worn (they were bought for my supra, so we're almost there) I'll downsize to a 295/25 and it should be good to go.
