Lowered on Swift springs and new grill and lights!
Lowered on Swift springs and new grill and lights! Update!!!!
Plasti-dipped the car today. Thought the grill turned out really well with the new black lights. Also, changed out my hi-beams to match my lows. They don't make the reflectors look blue like that when they're off though (flash from camera did that).
Also, lowered my fron't end only on swift springs. The front and the back have almost exact wheel gaps. The back stock height is still just a tad lower, but hopefully those Swifts will settle 1/8 - 1/4". Anyway, so much better! Also getting some 15mm spacers for all 4 corners Monday (I know, but don't care, so don't even bring it up).
Any the camber is WAY off from front left to front right. I'm guessing it could be this way from the factory since I still have a very minor pull to the right. Car still feels the same. Here's the alignment specs. Can't do anything about that camber.
UPDATE!
This is a picture with the front only lowered on Swift springs.
These are all pictures of the front AND rear lowered on Swifts with 15 mm H&R spacers all around.
So........................I went back and forth with myself, my installer, my friend, and several of you guys on whether or not to put the rears springs on. I finally decided last night (while at the installer) to go ahead with it. My installer was hesitant to do it after putting all the spacers on. After installing the rear springs, we actually couldn't even really tell a difference. We DID trim the rear bump stops inside the rear springs 1/2" as per the instructions in the box. All in all, I'm very happy with the look and the funny thing is, the back fenders still measure 26" from the ground (the same as with the stock springs). The front fenders also measure 26" from the ground. This is taking a tape measure from the ground and running it up the center of the wheel to the fender.
UPDATE!
Car looks good..and great color choice I'm assuming those swift springs will settle down a little bit, or atleast I'm hoping so. I just ordered a set of swift springs as well, and debating if I should put the front and rears or just the fronts like you did. Notice any difference in ride quality?
i saw brad's car a couple hours ago and it looks amazing in person. the matte black accents on starfire really look great. as mentioned, the wheel gap front to rear is damn-near even and is how I would want it ...i wouldnt do the rear spring swap if it was mine, especially since the teins on my 08 were a touch too low for my liking in the rear.
By the way, for you guys that have alignment issues, such as myself, Lexus told me they'd have to do a sub-frame adjustment. Geeze! It's always something. That being said, my tires don't show any premature wear at 8400 miles, so I might just live with it. Just hate knowing the camber's that far off. Hard to believe a $70k car would come from the factory like that.
