Our return to HPR for another lapping day.
Well after numerous tweaks and testing we thought we should at least head back to the track for a half day. It was time to test the OSgiken LSD, the FIGS/RB 2-Piece rotors and the front poly bushing replacements. Not to mention the new rear upper link set. We ran into challenges again with the oil temps but muscled through them. Also had a good amount of brake fluid boil which is no fun...soft pedal to the floor ![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
setup
![](https://a7.sphotos.ak.fbcdn.net/hphotos-ak-snc6/621688_10151098962278631_40886004_o.jpg)
Brakes did great. The XP8 compound held up nicely, much better than I expected actually. There was one incident during track bed-in that we had one side get a little too hot.
![](https://lh6.googleusercontent.com/-dIUQburJFc8/UEoVAXbC5mI/AAAAAAAAO-M/Ebq0d5fXw6U/w622-h412-p-k/IMGP8744.JPG)
We did finally get to the inner ring surface. Remember these were the narrower thicker rings that had a little bit of pad overhang with the factory pads. With the Carbotech pads oddly there were spot on.
before
![](https://sphotos-b.xx.fbcdn.net/hphotos-ash4/411541_10151098962358631_582142170_o.jpg)
After
![](https://a8.sphotos.ak.fbcdn.net/hphotos-ak-ash4/333207_10151098962103631_686741728_o.jpg)
The one thing I wish we had were the penske shocks on, which were sent back for final spec out (finally.) The setup here is an Ohlins front and a BC rear. The spring on the Ohlins was too soft and we had significantly more travel then I would have liked. Also stability was significantly less at high speed transitions. That held me back quite a bit on comfort. Another weird thing is that the car is stalling out around 4500-5000 RPM. It feels like a valve timing issue...like it hits a wall. I plan on stopping into the dealer to have them take alook since the motor is still under warranty.
A few action shots. The track only lends itself to one photo section without a good hike.
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash4/337736_10151098961893631_1528041955_o.jpg)
![](https://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash4/290579_10151098961843631_472906773_o.jpg)
![](https://sphotos-a.xx.fbcdn.net/hphotos-snc6/256320_10151098961768631_1268649403_o.jpg)
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash4/341204_10151098961693631_1129841244_o.jpg)
![](https://sphotos-b.xx.fbcdn.net/hphotos-ash3/621132_10151098962063631_708738045_o.jpg)
We should get the Penske shocks back in a few weeks and then I am going to looking into oil cooling augmentation. We are already running higher temp oil, Amsoil Dominator 15w50 and coolant was full. I am also playing with some sway bar options, just to get more info on what dynamics we can change.
A few other fun cars were there like this RHD converted EvoVIII
setup
before
After
![](https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/329556_10151098962173631_1879080226_o.jpg)
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
Fig
__________________
In regards to the oil temps and oil coolers, have you or anyone on CL had a chance to look at the CCS-R setup?
As for the brake fluid boil I was hoping to hear that the new rotors would lessen that problem. Are you thinking about a different pad combination, ducting for cool air, or a set of larger calipers? I know that a few Evos run titanium shims behind the pads on stock calipers to try and decrease heat transfer to the pistons. I knew a few people who ran brakes with titanium pistons on Porches back in the day (aftermarket addition to the Brembo 993 Turbo brakes). Unfortunately I don't know who made the pistons, how much they would cost, and I don't know if there would be anything 'off the shelf' for the calipers on the IS-F.
Looks like a fun track! I might have to make a road trip next year and run out there with you!
. Sorry to hear y were having so many mechanical issues....
. Do you think the Olin's would be better with stiffer springs?
Tech Info Resource
Why are you running 15w-50? Heavy oil ALWAYS runs hotter - a LOT hotter - and it uses more horsepower from a pumping perspective and a fluid drag perspective.
I'd bet a lot of money your cooling issues would go away with a 30 weight oil.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Great update, thanks for sharing!
Btw, what kind of lap times did the panel van put down?
Tech Info Resource
Video here:
Couldn't see video and pics in the same post.
Add a nice oil to air cooler stacked on the stock oil to coolant unit, and you'll be good to go with Xw30, as lobux said. Use at least -12 lines, maybe even larger... the 2UR pushes a good volume of oil.
I like the Racing Brake Rotors, been using those (un-through-slottled version) on the Tundra for a few years.
Which Ohlins damper type do you have?
Mike
__________________
Most of the DFV R&T stuff is made by Soqi in Japan (coincidentally, a Yamaha owned company) good stuff. The really good stuff (other than Penske) comes out of Ohlins Sweden, but one will pay for it. The TTX stuff is a dream to tune and it works so well as the design helps eliminate cavitation, amongst other things. Sorry for the high jack... I enjoy working with Ohlins products.
The coolant lines for the stock oil cooler are 12mm.... I wonder if using 14mm lines would be worth the effort?
