2010 ISF Aftermarket Sub Install
#31
I heard his setup this evening and it's a huge improvement over stock.... and I'm actually surprised he wants more bass!!
Install looks amazing too!
He's definitely got me wanting to do this to my F now...
wife will be pissed....
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
#32
great job, clean wiring and a great amp mounting job. not tying to be an *** but the 2 inch strips of sound deadener wont do anything. deadener only works if its covering a good majority like 70-90% of the metal. my experience with deadening my 250 was that the roof, doors, trunk lid, gas door, rear seat, and rear deck made a significant difference.
#33
http://www.sounddeadenershowdown.com/products/cld
#34
I'm a little confused. Does the L2Ci do the same thing as the JL Audio cleansweep, or are those 2 completely different things? I am trying to piece my system together now to make sure I do it once and right. I've seen multiple times where people say we need a cleansweep to work with our OEM system. I think it's too expensive tho and would love a cheaper alternative. Thanks for any help you can give.
Nate
Nate
#35
Yes and no - the l2ci is an advanced line out convertor while the JL clean sweep is a DSP. The DSP is supposed to cancel out the tuning. The factory system has in place providing a flat signal for aftermarket amps. The real issue is what are you trying to do... If you are replacing or adding an aftermarket sub / amp the clean sweep is really overkill (in my opinion). I used a l2ci to add an aftermarket amp/sub to the factory system. The factory system has an un defeat able 35hz sub sonic filter which neither product is going to fix. I can't speak to how well the DSP products work, although I've heard some have issues with the ML systems. They may work awesome but if all you are doing is adding a sub it's a large expenses that I don't believe is worth the additional expenses. If you are doing a full build out then certainly it's necessary. Doing a full build or replacement on the ML system is complex so if you aren't comfortable or familiar with these systems I wouldn't recomment you jump in.. It's very expensive iff you break something. Hope that makes sense - if not let me know. There are a few builds at diymobileaudio.com so be sure to check those out as well.
#36
Thanks for the quick response. I understand what the difference between those two products now. I just ordered a JL 12W7 and the JL HD750 to push it. Not going to change any speakers except disconnect factory sub.
I will probably go with the LC2i as it's 1/3 price of the JL. I been trying to do research tonight on multiple audio forums. The more I do, the more I realize I don't know nearly enough about systems as I thought I did lol.
I have a friend that has alot of experience in installing systems but I may just pay someone since our car is just a pita.
Awesome setup you have and thanks again for your help.: D
Nate
Nate
#38
this is awesome. thanks for the pics and info. Im thinking of doing this even though im somewhat happy with the stock sound from the ML system. i use to have a single IDMAX. very good stuff.
#39
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
The goal with CLD times is 25% coverage, which I'm sure I didn't hit (I mentioned this in my original post). But 100% coverage is unnecessary. The CLD Tiles are often paired with additional deadening techniques like MLV. I wasnt gutting the car and as I mentioned I had some CLD tiles left over so thats what I used - I am 100% confident it helped. Don over at sounddeadenershowdown has lot of info on sound deadening and he can help you put together a package if yo uare looking to deaden a car. I'm certainly not an expert but hes dedicated lots of time and info to perfecting sound deadening in Car audio applications at quite a bit cheaper than the dynomat/fatmat etc alternatives.
#40
Hey all.. long time listener, first time caller.
Nice clear and concise write up. Planning on doing almost the exact same install this next week.
Couple of questions:
- Why did you opt to use the amp's remote gain control vs the AudioControl's level control? Lower amp gain = less unwanted noise = better clarity.
- Why did you tap into the rear door sub wires instead of the main single sub wires?
For the record, I'm installing a single JL 13W3v3-2 13.5" sub into a ported box built by this guy: http://www.ebay.com/itm/261028027775...witem=&vxp=mtr
Power by a Sony XM-1S 500W RMS slim amp with a signal coming from an AudioControl LC2i. Not usually a Sony fan, but everything comes back super positive about this amp plus with the extra space needed for that sub, I can still fit both the amp and LOC behind the box.
#41
#42
Will do.
Already ditched the Sony amp in favor of a Hifonics GLX1000.1D and kicking myself for not doing so from the beginning. There was more room behind and around the box than we originally thought even after adjusting for the increased airspace of 2.5 cu/ft. I'll have to be a little careful with it as to not blow the sub with the CEA certified 750w from the amp vs the stated 600w RMS handling..![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
Tyler, the Ebay listing owner of Concept Enclosures, was super cool to work with and custom fit the box exactly to JL's specs for the 13W3v3-2 13.5" sub for the same price as is listed there. Can't wait to see what the 60% more air movement vs a 12" sub feels like in a nicely tuned and ported box..
#43
Will do.
pttlwin
IS F (2008-2014)
16
08-30-15 09:28 PM
dunbar43
02-07-10 03:23 PM
JonSC4
12
09-18-08 07:53 AM
