Minimum thickness of the brake rotors?
Hello, all
I've been reading most of the brake-related threads and the consensus is that the minimum thickness of the front rotors is 28mm.
I was browsing the Sewell pages today and found that they claim the minimum thickness of the F/R rotors are 26mm / 24mm respectively.
Link: http://is.sewellparts.com/accessorie...2009/2142.html
My friend just measured his rotors and it came out at 27mm. Your input will help a lot on his decision.
Thanks.
Thanks.
Tech Info Resource
The rotor has the minimum thickness stamped on it. If yours is a Korean model it might be different from the US models. The rotor's markings are beyond question.
