So my wife wants a wheel setup that can run wider tires than stock, and is pretty flush with the fenders. The wheel im looking at only comes in 20x8.5 F and20x10 R
You could run a 245 up front and a 285 in the back on the wheel sizes you listed. How flush to the fender they sit is going to depend on the offsets. If you want to make sure you don't rub and don't need any fender work, I'd recommend at least a +40 in the front and a +50 in the rear.
all about offset... I have 20x9 front, 20x10.5 rear.. offsets are +35 front and +40 rear.. and had to stretch the tires a tad.. 235/30-20 (f) and 275/30-20 (r)
Sick! Do you hve ay pics...my wife REALLY wants to run a stretched look, but still wants a wider tire in the back than stock.
im running the same set up i got a 10.5 with a 245 but i need to get a rim with a little less offset so that i can run a much wider tire in the back and front..i did fender work already and pulled my rears out a bit n still tired to keep the factory line but next rim i get will be a little less offset but same width so i don't brake traction when i punch it..so tired of it
