would 255's rub in the front??
The wheel specs are volk te37
Front +43 offset 19x 8.5
Back +34 offset 19x 9.5
I wanna run 255 35 in the front and 265 30 or 275 30 in the back... Would this be possible??
255/35R19 fronts will work with the spec wheel you described. For the rears...do you already have those wheels? I only ask because the rear offset will keep you from running a wide tire (i.e. you could fit a 295/30R19 tire on there with the proper offset). I'm not sure what size tire will fit with the rear offset you described. My guess is you could probably fit a 265mm tire, but you may have to trim a little...there are others here who could tell you for sure. If you do get a 265mm tire I would recommend a 265/35R19 over a 265/30R19. 265/35R19 is about .30" taller than stock while a 265/30R19 is about .75" shorter than stock.
Yeah I already have the rims. And I have these tires to work with...
235 35 19 or 255 35 19 from rear stock setup
275 30 19 or 265 30 19 for the rears
I really don't wanna spend more money on tires and would like to work w what I have.
Currently i'm running 265 30 19 and 10" +38 offset with no issues so im pretty sure i'll be ok since the new wheels are 9.5" . I think after offset calculation there about a 1mm difference between the two setups.
istundra
11-24-08 08:22 AM
bighitbike
06-11-07 10:23 PM
