Fox Marketing ISF
Old 10-04-12 | 06:10 AM
Gearbangin's Avatar
Gearbangin
Not sure how it was tuned just know it got crushed!
Old 10-04-12 | 07:03 AM
Lil4cyl's Avatar
Lil4cyl
I spoke to a guy at the dyno today who worked at Underground Racing. He said what they are doing to their 1700hp Lamborghini's is leaving the factory electronic alone, and using seperate injectors and fuel control computers to meter the additional fuel with boost. I would assume if someone was to work on this, a custom fuel rail with mounts for additional injectors per cylinder could be designed to work.
Old 10-04-12 | 08:07 AM
SeanGTS's Avatar
SeanGTS
Originally Posted by erick3
how pathetic. why would you think twice about a company like that?
Why not?! lol I certainly wouldn't mind a 600 whp IS-F! haha
It really isn't possible, so this may be yet another scam. With more power, you need more fuel. To add more fuel, you need to freaking be able to tell the ECU how much to add per given amount of air (tune, which requires the ECU to be cracked). I'm not an expert, and this is purely an educated speculation. Every car has a given "MAP," but you have to understand that these maps are meant to be universal - the car isn't just sold here in Seattle; the set parameters need to be able to adjust to different variables. Unfortunately, these parameters can only adjust so much. The goal of a tune is therefore to reset the parameters accordingly (AFR - you don't want detonation!). Their project ISF will likely blow up, soon. lol
(not lecturing here, just thinking out loud SeanGTS!)
I don't get it
MAP based verse AFM based was my question, does the car take airflow measurements from volume of air, or pressure?
It would seem tuning with methanol could be interesting.
Old 10-04-12 | 09:03 AM
ISF4life's Avatar
ISF4life
Talking
It was a Lexus Corp ISF prototype given to Fox Market for that project.
Old 12-17-13 | 02:34 PM
darbs242's Avatar
darbs242
Just read the article on the new 2013 fox marketing turbo isf... its done again and works i guess with minimal boost. Cant see why they would keep building them if they dont work. http://www.topspeed.com/cars/lexus/2...-ar138724.html I gotta call these people and see what the deal is, i know we can build a turbo kti cheaper than 17k.
Old 12-17-13 | 03:21 PM
DrRick's Avatar
DrRick
Motec M800 and lots of goodies...
Old 12-17-13 | 03:53 PM
chrisp1's Avatar
chrisp1
they run race fuel in the is-f as well
Old 12-18-13 | 06:41 AM
mikellucci's Avatar
mikellucci
Don't quote me but I heard hey turned to Syvecs for an ecu solution..if this were fact that car is serious! Google Nissan gtr syvecs
Edit- it might not be Fox but somewhere a v8 lexus is rumored to be working with a Syvecs!
Old 12-18-13 | 06:47 AM
DaveGS4's Avatar
DaveGS4
Forum Administrator
darbs,
That's the same car - article is from Nov 2012
Old 12-18-13 | 09:13 PM
crazee201's Avatar
crazee201
They reused the same turbo kit that they used on the first project car. I recalled Fox marketing trying to sell just the kit on this forum. The kit was stripped from the car before it was crushed.
Old 12-18-13 | 11:27 PM
Rossi's Avatar
Rossi
Why was the car crushed???
Old 12-19-13 | 10:38 PM
crazee201's Avatar
crazee201
Car had to be crushed because it had no VIN and it was only for a promotional use.
Old 12-20-13 | 10:10 AM
VtotheJ's Avatar
VtotheJ
The better question is why haven't they dynoed the car with the turbo kit and/or tracked it to see if it really works?
Old 12-20-13 | 10:18 AM
ISFpat's Avatar
ISFpat
I'm pretty sure they dynoed it but did not release the results, no company develops a custom turbo kit and ends up not dynoing it to check the AFR's across the board.. the kit most likely had some issues and the cost of R&Ding a car without a solid engine management system is more than enough reasons for them to not release the kit to the public.
Many newer cars even Honda Civic's have very difficult to crack ECU's. By the time a reputable company finishes the crack, develops a solid platform and tuner friendly software and releases to the public, the car will pretty much be on its way out and getting ready for the next car generation.
So IMO, no true engine management system solution and R&D to make it running perfect = it really didn't work.
Artem696
IS F (2008-2014)
40
05-16-16 07:00 AM
jat0223
IS F (2008-2014)
13
01-27-14 08:06 PM
TXCarguy
IS F (2008-2014)
10-27-11 07:18 AM
is-fowner
IS F (2008-2014)
06-01-09 04:18 PM
Quick Reply: Fox Marketing ISF
